Need help in phoenix
Anybody in the Phoenix area that can reprogram my fan start and stop temps. I'm not asking for a freebe.
Try XTREME MOTORSPORTS in Tempe...
Thanks for the quick reply. They will only do with a complete tune. More that I wanted to spend right now.
Probably more than you want to spend but forum vendor Maryland Speed sells the Predator Diablo for $279 +/- You can set the fan on/off and other parameters. Unfortunately it is "married" to your vin so someone can't use theirs to help you. It is a nice tool to have though. HTH
You might call the Loud Pedal Motorsports in Tempe. The owner is a big Corvette/Camaro guy.
I've got a lead for a shop in Chandler, total cost $80.00. I've got an apt for Sat. I'll get back with you on Mon.
Last week or so a company called SACCITYCORVETTE, had a thread with information on their product, cool it. Its a fan relay replacement. It uses a fob to turn your fans on with the push of a button. $49.99 and very easy installation. It looks good to me for those time you need a little more cooling.
Question: Are you changing the stock thermostat?
Yep, did the waterpump, t'stat, and cleaned the radiator and condenser coil. Hot weather is on the way.
Thanks for all the help. |
If you can wait a while until figure out where it is I can do it via HP Tuners, but for the program to take you have buy a couple of credits. I think they are about $50. You can simply change the "fan on" setpoint. I think stock it is set at 210, but you can move it down to 200or lower.
Originally Posted by AZDAVE
(Post 1577083158)
Originally Posted by neaz
(Post 1577095094)
I really don't see you having an issue if you've done all this unless you have some serious mods to the car. I had some heating issues a couple years ago in which I had LPM put in new stock stat and clean the radiator/condenser and I haven't seen over 230, even idling in rush hour during the summer
