C4 Corvette Overheating
Hey guys, went to start up the vette today after about 4 days and when I turned the key it started to crank then i heard a deep pop come from the engine. Afterwards my car is running about 20-30 hotter (about 180-200) than normal and heats up rapidly when just idling..... (up to 220 at one point) :/
Any suggestions as to what could be going on? Thermostat stuck...? I know that's not very hot but still seems alittle odd and I'd like to fix it. Thanks guys. |
I vote 'burp' it first, and see if that helps, then with it cold, open the cap and check for air bubbles.
by burb do you mean bleed the system?
The mechanic that I use says that he's seen a lot of C4s do the same thing. He says that the higher mileage and age on the idiot gauges are usually the problem. Try a higher temp thermostat.
I think there may be something stuck in the fan or in the radiator like a bag or something. Im at work though so ill check it when i get home. (didnt drive it to work). Im thinking= its a piece of trash though becuase it only heats up when im just sitting there. As soon as i get moving its fine. But garyimes7 i highly doubt it the gauges or something big just becuase my vette has 55000 miles on. Its practically brand new. Im thinking its just trash. If not ill try a new thermostat. Thanks guys
Originally Posted by GARYIMES7
(Post 1577235074)
As with all cooling problems, eliminate the easy things first. http://temp.corvetteforum.net/c4/vad...erheating.html That link is the basic steps to go through. |
Originally Posted by crzydrumer14
(Post 1577233626)
(Post 1577231154)
(Post 1577235074)
(Post 1577235074)
(Post 1577235074)
If your car is running 180-200, you need to find something else to worry about. The "pop" you heard was a cat escaping when you hit the key....unsuccessfully.. :lol:
Originally Posted by Sweet 90
(Post 1577242819)
Your mechanic??? I wouldn't let that guy touch my lawn mower:willy:
update... I was just paying extra attention to everything after that pop. Scared me there. haha. its all good. checked it all out last night; space in between condenser, radiator itself, thermostat, and fans. All checked out. I just got the car like a month ago. Its all good. Still getting used to it and how it runs and what the gauges normally read. False alarm. Thanks though.
(Post 1577248692)
(Post 1577242819)
Those mechanics are why my corvettes remain in my garage under multiple locks n keys...with parking brakes applied and a couple large trucks parked in front of the garage door... with kill switches :rock::rofl: |
I know the problem on overheating or raising temperatures no one has mentioned yet. Check under neath the very front of your vette. Is there a plastic spoiler hanging down? Notice Corvettes dont have a front grill like most cars so, air needs to be drawn up from underneath. These get ripped off from those cement parking lot blocks. If you are missing yours, buy one install it, and then reduce your thermostat to 185, then Walmart has a coolant "add to any color and any type" coolant (its green), its a white bottle. Do these 3 things and your done, I guarantee, mine is at 185 perfect at night, 215 on a hot day, 225 in traffic, but the fans come on then and reduce temps to 203, then go back up, then down. But check underneath, I'll bet that wrap around spoiler might be gone.
