Drive Shaft Markings/Finish
I did the search on the driveshaft finish and natural (nothing) seems to be correct. Are there any factory paint marks on the driveshaft? The guy that owns the shop (old guy) and balances the driveshaft thinks there might be a green mark somewhere on it. Any thoughts, maybe pictures??
65 Roadster L/79 4-speed 3.55 rear end |
Originally Posted by mgoeppert
(Post 1577316929)
65 Roadster L/79 4-speed 3.55 rear end Big block cars use a shot-peened half-shaft and yoke assembly and is so identified with a dab of lime green paint on the shaft.:cheers: |
(Post 1577316929)
Originally Posted by 4440stevesvette
(Post 1577319382)
Driveshafts and halfshafts are a natural finish welded to natural finish forged steel yokes. The weld bead should show a moderate amount of discoloration due to heat from the welding process.
Originally Posted by vt65
(Post 1577323579)
So why are so many of them painted grey?
Originally Posted by DansYellow66
(Post 1577326966)
Because they are often rusty and pitted from years of service and painting them is an easy means of making them presentable.
