Steering Wheel Position??
I had the steering rack & pinion replaced over 2 months ago. Ever since the the first day from repair, I've kinda wondered if the steering wheel was "centered" properly. The steering wheel always appears to be cocked" more to the right slightly than in a centered position. My question is: how can I make sure the steering wheel is perfect "TDC" as it should be and not just my imagination? Thank you.
Find a nice, long stretch of highway and see if the wheel is straight when cruising. If you're going straight you'll be able to tell if there is a problem. If the wheel is off a bit, once you straighten it, the car should change as well.
Originally Posted by 1998prince
(Post 1577330978)
Try and find one that is flat side to side too.. If it slopes or has a crown, the wheel will have to be held to one side a tiny bit to correct for that. Wheel centering is easy and is part of a front end alignment. If it proves to be off, take it back to the shop that installed the rack and aligned the steering in the first place. |
Sorry, I'm in Texas and tend to forget other parts of the country have elevation changes. :hide:
Originally Posted by Sandpiper59
(Post 1577331725)
If it was a shop that did the rack, they should have done a 4 wheel alignment afterward as part of the procedure. And they should have ensured that the wheel was centered. Take it back and complain. |
(Post 1577332648)
Originally Posted by Frizlefrak
(Post 1577333175)
Funny.....El Paso got the mountain, and the rest of Texas got the trees....:rofl:
(Post 1577331725)
Wheel centering is easy and is part of a front end alignment. If it proves to be off, take it back to the shop that installed the rack and aligned the steering in the first place. it a "cog" or 2 on the gear shaft, but under the hood in the steering assembly? Thank you for the reply.:thumbs: |
Originally Posted by Donne Trav
(Post 1577347806)
Are you saying this is not done by removing steering wheel to rotate
it a "cog" or 2 on the gear shaft, but under the hood in the steering assembly? Thank you for the reply.:thumbs: Turn it full lock each way. If at lock, it is the same angle to each side, then it is centered to the rack and just needs toe correction, if it is different at each stop, then it needs centering on the shaft itself. |
(Post 1577347806)
it a "cog" or 2 on the gear shaft, but under the hood in the steering assembly? Thank you for the reply.:thumbs: Adjustment is through tweaking the outer tie rod ends. Lift front of car so tires are off ground. Turn wheel full left...use something to reference a point on the wheel...turn wheel full right and note position with respect to reference point. Center is exactly in the middle. Will probably take a few cycles to find the exact center. Use masking tape on the wheel and column to make an alignment mark....take back to shop or just have an alignment done and make sure they center the wheel. |
Originally Posted by LannyL81
(Post 1577348075)
The steering wheel will only go onto the shaft in one position...so no you cannot move it a cog or two.
New wheel
Hey guys look at my new custom wheel. Takes a long time to get but worth the wait
https://cimg4.ibsrv.net/gimg/www.cor...4d9083ee8c.png Here is my new wheel |
Of what 'significance' is this post to a thread that's 10+ years old that had nothing to do with 'appearance', just 'centering'? A post in the wrong 'Generation Forum' for sure. What do I think of your new wheel? Your $$$ so ....................................... |
Originally Posted by WVZR-1
(Post 1605715311)
He I posted in the wrong section excuse me
You guys know that this forum has the "related thread" feature at the bottom of the threads. Well, less of a feature and more of a bug: it makes it a lot easier to accidentally scroll to the bottom and post in some old thread that's only tangentially related.
