Parking Light Troubles
When I activate my left turn signal both lights front and rear on the left side work(blink) but when I pull out the light switch half way to activate the parking lights the front left light does not work.Obviously the bulb and wiring are ok-can the problem be the light switch,although all the other 3 lights function properly when the switch is activated.Any help would be appreciated.thanks.
Signals
Originally Posted by saraholt61
(Post 1577335668)
RON |
You have a bad bulb. The parking light and the turn signal in the front parking lamp assembly use different filaments. It takes an 1157 bulb that has two contacts and two filaments.
Originally Posted by LB66383
(Post 1577335967)
