Water pump drive shaft has to play - is this normal
I am replacing all the timing cover seals. When I pulled the cover I noticed the water pump drive shaft has some play. It will move slightly from side to side. Is this normal or should I replace the bearing and is it sold as an assembly or just the bearing?
Thanks, Jim |
That's normal. Once the water pump and coupler is installed that movement will be gone.
Thanks, I really appreciate the quick response.
Jim |
