2001 bose radio lights are out
I have a 2001 coupe with the factory bose head unit. The display and the radio itself work fine, but all of the lights are out. I removed the radio and opened it up to find that all of the bulbs are fine. I am wondering if the BCM controls the illumination circuit independantly of the display. Has anyone else had the same issue? Could it be the BCM or a circuit inside the radio itself? Thanks for any help.
Originally Posted by odin65
(Post 1577966270)
Hope this helps.....by the way...my vert is also a 2001 |
Bikerbob61, Thank you very much for your help. I guess I may have that excuse I needed to change the Radio. Thanks again
(Post 1577970501)
As another option, you could contact JW Motoring and see if they can not only fix the lights, but also maybe put in some LEDs while they are there.
Time for a double din.
xxx
