233/239 cam w/stock manifolds
im in the process of a TSP 233/239 @112lsa cam install and was wondering how much power do you think i will lose if i keep my stock exhaust manifolds and stock exhaust system?
I've heard that the exhaust manifolds changed in 2001 to flow better (i have a 2002 C5 with 241 heads). was just wondering what ya'll thought of running with stock manifolds. think i can make it into the 11's (1/4mile) without LT's? (241's w/upgraded springs, LS6 intake & 233/239 cam.... its an M6 car and im a very decent driver) |
I am sure you understand that is not an optimal setup, or you wouldn't be asking, but that being said. I believe with M/T drag radials, you could probably sneak into the 11's with that setup. Auto or stick? Solid 12's are pretty common, so 11's with tires and a bit more power is do-able, but probably on a glory run, and not back to back to back. Good luck, and post the results for us nay-sayers. LOL Steve
Originally Posted by Heimlich2010
(Post 1578075825)
.598/.603 ...
For the most part its my daily driver (I alternate between this and my 88 c4). Im hopen to be pleased with the cam swap even without LT's |
(Post 1578076436)
.598/.603 ...
(Post 1578076436)
.598/.603 ...
The springs are being upgraded to double springs w/ max lift of. 650. Im aware they are more fragel when cold. 241s don't flow well over. 575 lift? I did not know that. So I guess I will be porting my 241s. Does everyone think unportred 241s wont properly support my cam?
No offense that cam is too big for 241s . It will work, but a smaller cam will get you much more HP out of the 241 heads.
Ported 241s really wont help. You need at least 243 heads but still really do not flow much above .600 so no need to have a cam with lift above .598 - .600 Too make more HP it is a whole package that makes it work. not just a cam or heads or LTs Cam, Heads, LTs, fast 92/92 intake and CAI, with supporting parts and a great tune Good Luck |
I made 413WHP and 396RWTQ with my MS3 cam, 241's, and bolt ones. You will be just fine with the stock heads for now.
Originally Posted by 0331MARINE
(Post 1578083564)
now from what ive read and please do correct me if i wrong on this but there are two versions of the 243 head,,, an early version that is almost identical to the 241 (except for combustion chamber size 243=64cc, 241=66cc). as i have read it the early 243's dont flow any different than the 241's but the later 243's outflow the early 243's and the 241's.................. like i said please correct me if im wrong.
Getting a cam that has more lift than where the heads flow max is definitely a good idea, think about it, you pass that lift and max flow TWICE, on the way open, and on the way closed. Anyways, looking at the lift of the cam means that you are worried about the wrong thing. You pick the rpm range you are running in, then pick the lobe, and let the lift fall where it falls. Lift is the least important of all the factors.
Originally Posted by p1bz
(Post 1578090326)
(Post 1578083564)
I have the 233/239 cam, number in my sig, however you using 241 heads with stock exhaust is going to hold back about 50 RWHP over some ported 243's with full exhaust maybe a bit more.
thanks ya'll for all the info it is much appriciated. im going to port the stock manifolds (no nay saying i already know), hollow out the cats (i had a sick 383 stroker in my 81' vette with hollowed out cats, it worked), put the car on a dyno and post the results to this thread (might be a month or so).
Then i will add LT's :thumbs: |
FWIW, when I had the 233/239 CAM ONLY with full exhaust/straight pipes I put down 380 RWHP, so with stock exhaust expect about 15-20 less than that.
Originally Posted by Corvette Don
(Post 1578091321)
Originally Posted by ZZ06
(Post 1578088294)
hey 0331marine i thought you had a ZO6??
(Post 1578091929)
Nope, just a little LS1. :cheers:
