Anti-spotting sgent
I prefer to wash my car, except when it is 92 here in Florida. Mr. Clean used to sell a car wash unit that had an "Anti-spotting" spray that was sprayed on your car to rinse it. It is no longer available.
Has anyone ever found an anti-spotting spray that I could use so I don't have to wipe it off? Tom |
CrSpotless is a much better system, it actually works, but it will cost a bit more than the Mr. Clean system. You can also consider adding a water system inline which will remove alot of the contaminents and minerals causing spotting.
http://www.autogeek.net/cr-spotless-water-systems.html or http://www.autogeek.net/clinhofianda.html |
Originally Posted by tombobb
(Post 1578087887)
Has anyone ever found an anti-spotting spray that I could use so I don't have to wipe it off? Tom The benefits of using it are that it prevents "spotting" caused by droplets of water drying and leaving behind dissolved lime scale minerals, and can also improve drying performance as there is less water remaining to be dried its drawback is that it leaves a thin film on the dried surface. This type of surfactant can be found in 'Rinse Aid' an additive for dishwashers, do I know of a car care spray with these attributes, no. But as Scott has suggested CRSpotless is the best solution to this problem |
