Pro Street 89 Build
I have been motivated by several other builds on the forum! Our new project is to build a Pro Street / Drag 89 C4. The goals are to back half the car, 750 to 1000 hp small block, front coilovers, try to make it a bit unique and to do it on a limited budget. Not looking to sacrifice quality, safety or performance, but this is going to be a true garage build. These builds are never cheap but we plan on using good quality used parts, buy, sell and trade parts and anything else to control cost.
Starting with the base car. We found this 89 C4 that fit our needs perfectly. Good body, good paint, engine and trans with 50,000 miles, good wheels and tires and good suspension. The only problem was that, for whatever reason the previous owner had butchered the wiring in the car. Wires were cut in the ignition system, headlights, etc which made this car unattractive for buyers looking for a good driver but perfect for me! Purchase price was $3300 and I am pretty sure I have the engine and trans sold. I am hoping by the time I sell off the parts I dont need I will have less than $1500 in the body. If anyone is needing a rear end or other parts I wont use in this type of build just let me know. Here is a pic of the base car as it sits right now. Actually it still runs and drives fine so I have kept it together as I gather parts for the build. I will show what I have gotten in future installments. http://forums.corvetteforum.com/pict...ictureid=87913 |
If anyone has any ideas, suggestions, or parts they think I might be interested in, give me a yell! I have already talked to several forum member and gotten some great info and help.
As a budding drag racer trying to get my 2 c4s to go down the track faster I am jumping on board for the ride too.
First questions? 1. How exactly will you "back half the car"? (http://autoweldchassis.com/Instruct.ivnu) 2. Why change the suspension on the front? |
Or you can go on racing junk and buy a pro street for less than it will cost you to build. I see them for 8K and up for a great starter.
Unless you just care about doing a project and money is not the issue. |
Originally Posted by pologreen1
(Post 1578199534)
Unless you just care about doing a project and money is not the issue. http://www.corvetteblogger.com/2011/...om-down-under/ |
You can sell the seats, and all the interior parts and come out ok, but it's going to take time and work. There is a guy with a red corvette who is backhalving his red vette, similar year. Doing a fantastic job, by the way...Read the whole thing.
http://forums.corvetteforum.com/c4-t...s-project.html These guys are correct, it going to take time, skills and money........and patience. If you could fine one partly done, or find a bolt in solid rearend from Rod and Carrols racecraft, that could save you a lot of headaches. http://www.rodandracecraft.com/products_corvettec4.htm You'd better have some great welding and fabrication skills before attempting this. Not saying you don't, just saying. 9 second quarter mile times in a less that superior chassis isn't smart. I've built several cars over the years, thay always cost more money, take more time, and there is always just a couple of more things to do.... Here's a short list. Sell your parts Engine Transmission/shifter Differential Chassis upgrade (backhalf or roll cage) Fuel system seats gauges wheels tires brakes....and whatever it takes to stop it. cooling system hood modifications and paint 2-3 years of you spare time, and all your money! It's a big project.:thumbs: Good luck!!! |
I have tossed the same idea around before as well. Good Luck! :thumbs:
Originally Posted by Lemme
(Post 1578199223)
First questions? 1. How exactly will you "back half the car"? (http://autoweldchassis.com/Instruct.ivnu) 2. Why change the suspension on the front? I am not looking to change the front suspension too much. I do want to get rid of the mono spring and go with a coil over in able to get a better ride height and adjustment. I may also go with an adjustable upper a arm and sectioned lower to bring the tire a little further into the wheel well. |
Originally Posted by cadmaniac
(Post 1578200115)
http://forums.corvetteforum.com/c4-t...s-project.html These guys are correct, it going to take time, skills and money........and patience. If you could fine one partly done, or find a bolt in solid rearend from Rod and Carrols racecraft, that could save you a lot of headaches. http://www.rodandracecraft.com/products_corvettec4.htm You'd better have some great welding and fabrication skills before attempting this. Not saying you don't, just saying. 9 second quarter mile times in a less that superior chassis isn't smart. I've built several cars over the years, thay always cost more money, take more time, and there is always just a couple of more things to do.... Here's a short list. Sell your parts Engine Transmission/shifter Differential Chassis upgrade (backhalf or roll cage) Fuel system seats gauges wheels tires brakes....and whatever it takes to stop it. cooling system hood modifications and paint 2-3 years of you spare time, and all your money! It's a big project.:thumbs: Good luck!!! Even though we are trying to be somewhat budget aware I do know we arent doing everything as cheaply as we could be. I could have bought a started project or gone with a bolt in rear, but we like the pride of doing the build, and I want to run bigger tires than a bolt in will handle. I do have a decent amount of building and fabrication experience. I have either built or helped build 2 tube chassis cars, 2 rear engine dragsters and 1 altered. Most were in a better supplied area than my garage but the altered was totally built in my garage (you can see it in my pictures). I totally agree with the taking more time and money part. I usually think of what it may cost and then at least double it! lol |
Originally Posted by RUKWKR
(Post 1578202715)
Originally Posted by SpeedRacer61
(Post 1578203120)
All ready done my friend! I have already read all your thread and printed it out for reference! I only hope my will be as nice as yours! I am the one that contacted you about a month ago about the pictures of you front a arms. Thanks for the info and help!
Good luck! Also, since you are so close you are welcome to take a look at the car anytime. |
:cool::lurk::cheers:
is this an auto or stick car?
Subscribed,
Good Luck with your New project Pro Street C4 Build. :thumbs: |
Well, it sounds like you are very motivated. I'm excited to watch this build. The car is going to be awesome, and it sounds like you have the skills to git-er-done...
I'm looking forward to following this !!!! :lurk::thumbs::cool: |
(Post 1578209201)
Originally Posted by 88BlackZ-51
(Post 1578207552)
(Post 1578205060)
Ah yeah, I remember your forum name now!
I will follow your build closely. Mine is coming a long slowly. Working on the Convertible now, but will be working on the coupe off and on too. Looking forward to seeing your back half and cage come together. That was a ton of fun on mine. Looking foward to getting into the drivetrain on mine text
Tachout (Red Vette) |
