KATECH Ultra Track Attack Z06- 717hp/2900lbs - The Ultimate Track Toy Concept
Here is a concept package to get your engines revving. Can you imagine a group of these in all different colors terrorizing the road courses of America?
http://i81.photobucket.com/albums/j2...1/DSC_0072.jpg ULTRA TRACK ATTACK Z06 SPECS: Not legal for road use in the United States. For track use or export only. However it would be street-able for vehicles operating outside of the United States. 717hp 650ft-lbs 7000rpm redline 2900lbs or less 4.0lb/hp Estimated performance: 0-60 2.9s 1/4 mi: 10.9 @ 140 Top speed: 180mph wing on, 210mph wing off Skidpad: 1.5g Nurburgring with Mero driving: 7:00 ENGINE - Katech Ultra Track Attack LS7: 4.205 bore 4.250 stroke 472ci Dart/Katech Billet block Forged 4340 crankshaft Forged H-beam rods Forged 2618 pistons DLC coated pins C5-R timing chain Aggressive camshaft (hydraulic roller) Single beehive valve springs Titanium valve spring retainers High speed lifters CNC-ported LS7 heads Titanium intake valves Sodium filled hollow exhaust valves Bronze valve guides FAST LSXR 102mm intake, painted satin black NW 102mm throttle body Katech billet fuel rails Katech AN fuel lines FAST injectors ATI damper Dailey dry sump pump (4 scavenge, 1 pressure) Oil tank Dailey Billet oil pan Katech billet front cover Katech billet belt tensioner Katech aluminum valve covers, powdercoated Katech coil relocation kit Katech spark plug wires Halltech CF112 intake Halltech Superbeehive http://www.katechengines.com/street_..._low%20res.jpg Dailey system not pictured EXHAUST: Kooks headers, ceramic coated X-pipe Corsa mufflers Koolmat tunnel heat shield Gold film heat shield shielding COOLING: Dewitts radiator Integrated oil cooler DRIVETRAIN: RPM level V trans and diff, micropolished Quaife differential Pfadt carbon fiber driveshaft Exedy twin disk clutch BRAKES: Brembo GT 15" front Brembo GT 13.6" rear Slotted 2pc rotors Spindle ducts SUSPENSION: Moton Clubsport double-adjustable coil-overs Pfadt competition sway bars Pfadt pillow blocks Pfadt camber kit Pfadt poly bushings SKF hubs ARP wheel studs Interior: Caravaggio hand stitched alcantara steering wheel with flat bottom Caravaggio hand stitched alcantara parking brake boot and knob Caravaggio hand stitched alcantara shifter boot and knob Caravaggio hand stitched alcantara center console lid Caravaggio Daytona seats with alcantara centers, carbon shell and belt pass-throughs 4pt roll bar, 6-point optional Schroth camlock harnesses http://img.photobucket.com/albums/v3...naseats002.jpg BODY/AERO/EXTERIOR World Challenge carbon fiber lift-off hood Hood pins Katech carbon fiber front splitter with undertray and integrated brake ducts Katech front fascia reinforcement Katech carbon fiber side skirts World Challenge carbon fiber wing Sticker package with customized number selection and driver/passenger names WHEELS/TIRES: OZ Ultraleggara HLT wheels 19x10 & 20x12, black Michelin Pilot Sport cup tires 285/30R19 & 335/25R20 http://i81.photobucket.com/albums/j2...1/DSC_0065.jpg est. $113k plus base vehicle |
dayyyyuuum. thats badass.
Photoshopped with black headlights
http://i1121.photobucket.com/albums/...8/DSC_0060.jpg |
Black headlights really pop. I think you should make the change.
Car looks good Jason, all except the wing, but I understand it's there for a reason.
I definitely like the black headlights! |
"Not legal for road use in the United States."
I guess you must be located outside the U.S.A? HAHA LOL:thumbs:, that package is amazing and if I had the disposable income I would write you a check in a heartbeat for a MONSTER setup like that! |
Impressive in the extreme!
Originally Posted by BigMike NY
(Post 1578254813)
I guess you must be located outside the U.S.A? HAHA LOL:thumbs:, that package is amazing and if I had the disposable income I would write you a check in a heartbeat for a MONSTER setup like that! We are in the US, but I can see Canada from my house. (in a Sarah Palin voice) |
Originally Posted by Katech_Jason
(Post 1578254830)
Wow, that concept car looks just like your car Jason! That would be (is) an awesome package for sure.
Will we get to see it at a Track Attack event next year? |
Originally Posted by Everett Ogilvie
(Post 1578255274)
Ummmmm.....YEP!
Cool stuff Jason! Always happy to see the Track Attack cars come to life! Great builds and cool pics. Glad we can help!:thumbs: |
Jason, are you going with the Caravaggio seats? Do you know the weight savings?
Jim |
(Post 1578255545)
You will see my car at TA12.
Originally Posted by Halltech
(Post 1578255569)
Jim |
(Post 1578255613)
What is TA12?
2 things: You need black headlights and the only other thing missing is ZR1 brakes. :D
200 grand , what a deal
What is redline with the 4.25 stroke?
