Steering Wheel
These may be silly questions but here goes:
1. What does the button that has a "1-6" on it do? 2. I have a 6 speen automatic paddle shift. How do I get the display to read out which gear Im in? I did it by accident once and cannot repeat it. |
Cycle thru radio presets "1-6".
Originally Posted by JeffinGH
(Post 1578275765)
1. What does the button that has a "1-6" on it do? |
Actually cycles through presets 1-6 on FM1, 1-6 on FM2, AM and back around I believe.
(Post 1578275765)
Good question on #2, hope to hear the solution.
Not to hijack, but what is the 1>4 thing on the speedo mean/do (my owner's manual is in the car twenty feet away, I'm comfy at the 'puter w/a cold white russian (happy Saturday!) ? |
Regarding the gears in paddle shift mode...
It displays in the HUD while you are paddle shifting. Mine does it all the time. I don't think it matters wether you are in street mode on the HUD or track mode. |
(Post 1578275765)
Originally Posted by Thrash
(Post 1578275909)
Not to hijack, but what is the 1>4 thing on the speedo mean/do (my owner's manual is in the car twenty feet away, I'm comfy at the 'puter w/a cold white russian (happy Saturday!) ? Or too many white Russians?...:willy: |
Thanks
Thank you gentlemen!
(Post 1578275909)
(Post 1578275765)
# 2. for paddle shift mode: Pull floor shifter all the way back to "S" then on paddles downshift. Once this is done the gear you are in will appear on the DIC. you can then cycle up or downshift through gears.
(Post 1578275909)
