1977 Small Block: Engine block antifreeze drain plugs location
Trying to locate the engine block drain plugs to drain the anti-freeze out. Can anyone help me locate exactly where they are? Are they easily accessable or (like almost all other jobs on this car) do I need to remove a million things to access it?
Any help on accessing and finding these drain plugs would be greatly appreciated :) -D |
Originally Posted by bruisedknuckles
(Post 1578295110)
Are they easily accessable or (like almost all other jobs on this car) do I need to remove a million things to access it? |
Deleted
Originally Posted by MelWff
(Post 1598967993)
Is the antifreeze and general condition of the cooling system that bad that you feel you have to remove the freeze plugs?
No shit....I accidentally posted on it...and then so did another after a “bumped” it....
Jebby |
(Post 1598968624)
if everybody goes into EDIT and selects delete all are misposts will go away..
Maybe it is my browser. Jebby |
hit edit. then delete. then there is a checkbox set at do not delete. set it to delete. it worked for my post. i will come back and delete this tonight.
There's nothing wrong with keeping a useful post like this alive. This was the first hit on Google when I searched for this topic.
I was able to get the drain plugs out of my 80 L48. There was no gunk behind them, just slightly rusty antifreeze. The plugs were the original steel, which I will replace with brass. Here are pictures of the locations to help someone searching for this information in 2027. Both plugs were easy to get to, with the exhaust out of the way. Just be sure to have a bucket ready, the water will shoot out further than you expect both times. https://cimg2.ibsrv.net/gimg/www.cor...fa47b99e21.jpg https://cimg3.ibsrv.net/gimg/www.cor...206c6aadc3.jpg https://cimg7.ibsrv.net/gimg/www.cor...dc1bd5a9c2.jpg |
