ZZ4 valve adjustment
what is the spec/procedure for adjusting the ZZ4 hydraulic roller lifters?
Bill |
I'd do it hot and running with a cutout valve cover to shield the mess. You know the drill, back off until it clatters, back in until it doesn't and go in another half to three quarter turn.
At least that's how I would do it. |
thanks...
according to this post in the H.A.M.B; maybe, or maybe not http://www.jalopyjournal.com/forum/s...d.php?t=583627 Bill |
I did a search and found about a zillion different opinions. :willy:
Why are you having to adjust? Did you miss a shift?:lol: |
Originally Posted by claysmoker
(Post 1578435729)
Why are you having to adjust? Did you miss a shift?:lol: i just figured that hydraulics are supposed to be quiet, therefore they need to be adjusted.. Bill |
Maybe just pull the covers and take half a turn on all the nuts. That will fix it!:leaving:
maybe...
i guess you and i are the only ZZ4 'experts' on here. Bill |
No need for an "expert"........... adjust like any other hydraulic lifter SBC.
Plasticman |
Originally Posted by Plasticman
(Post 1578437661)
Plasticman |
(Post 1578437661)
Plasticman |
Same roller lifters and rockers used on the 86-91 L98s and 92-96 LT1s. Probably get many people chiming in if you post in the C4 section.
:cheers: |
Originally Posted by ZBRA
(Post 1578440924)
:cheers: there seems to be many 'opinions' as to how many turns and whether they are just 'noisy' no matter how they are adjusted... :willy: i figured with all the ZZ4s that people have stuffed in their C1/C2 that someone(s) would have the 'facts'. Bill |
