What size belt? Flip drive w A&A pro charger ?
I have a A&A pro charger newest bracket 8 rib
And need the belt to run with an 3.55 blower pulley and my crank pulley is innovator west 10% overdrive size 8 rib. Used with a D1sc What size belt to get? And what kind is best? Where do I buy from? Thanks guys! |
I can give you for a 4.25 later if you want...
Originally Posted by master blaster
(Post 1578653425)
And need the belt to run with an 3.55 blower pulley and my crank pulley is innovator west 10% overdrive size 8 rib. Used with a D1sc What size belt to get? And what kind is best? Where do I buy from? Thanks guys! Kiss my ass! I have the same set up down to the pulley and crank pulley. It took two days and 5 belts later to get the right one . :ack: It's a gates belt 56-1/4" 8 rib belt will do it, at least foe me. Bout mine at Oriely Good luck |
that sounds about right... mine was 57.0 or 080570... held at 26psi..
Originally Posted by joshtownsend
(Post 1578654822)
Originally Posted by regorih
(Post 1578658116)
At26 psi? What set up was that to hit 26 psi?
