86 power steering pump problems
When car is cold power steering works worse, and it doesnt work at all at the begining of a turn then all the sudden works fine. It also works better or with no problems at all when its at higher rpms. I have no leaks and the fluid is real dirty. My question is is my pump bad or rack or both?
whats the condition of the serp belt?
Is the pulley spinning on the shaft? |
the belts in good condition ill check if its spinning im sure it is
"Survey Says:" your rack is worn. 'Classic symptoms of what is called "morning sickness". The rack piston rides in an aluminum bore. Eventually the bore wears. Rebuilt units are steel sleeved and won't wear out on you. :thumbs:
1 Attachment(s)
Originally Posted by DanZ51
(Post 1578808255)
Originally Posted by pmihaltian
(Post 1578810317)
:iagree: However, you might consider flushing out your old fluid and replacing it with a good systhetic. The new fluid may work better for you. Here is a how to write-up.
