C6 Kicker Speaker Upgrade kit only $79.99
Replace your factory 3.5" front door speakers and 5.25" rear coax speakers with our Kicker upgrade package. $79.99 You will get: 2- Kicker DS 35 3.5" Coax Speakers for front doors 2- Kicker DS 525 5.25" Coax Speakers for the rear 2- Pair of Metra 72-4568 GM Speaker Connectors Simple install! No cutting, no splicing! Minimal investment to upgrade your stock audio system! http://i45.photobucket.com/albums/f6...ickerds525.jpg http://i45.photobucket.com/albums/f6...ezels/ds35.jpg http://i45.photobucket.com/albums/f6...s/kickermt.jpg |
How about something for the bigger door speaker.
Hmmm, :thumbs:
Do you still offer the Focal speaker special?
Originally Posted by blacklsx
(Post 1579151335)
yes sir all day every day:thumbs: http://shop.doubledmods.com/FOCAL-Sp...ages_c1056.htm |
Originally Posted by 07blkvette
(Post 1579151105)
we can do this but will be an entirely different install. Those are amplified so we would need to power them with an amp or aftermarket radio Not as simple as this would be We can discuss more in whats involved if you like :thumbs: Just give me a call sometime. Thanks Dennis |
Hello Dennis! Sent you a PM with some questions! thanks Henry
Do you have a DIY instruction on thow to remove the stock speakers?
Originally Posted by Venom_C6
(Post 1579153077)
I am workign on putting a PDF File together now that will be posted on website under installallation info. Its really pretty simple and untill then a search will get you alot of info rear speakers http://forums.corvetteforum.com/audi...to-w-pics.html removal of door panels http://forums.corvetteforum.com/audi...anels-off.html Thanks Dennis |
So if I was going to replace the 10 in the doors with a 6.5 I would have to have an amp? I would not be able to plug them in and go?
Originally Posted by DUMAN
(Post 1579154156)
correct you would need to add an amp with amp kit and the aoem-gm24 harness that will give the stock radio preouts as well this is what this package is put together the way it is for a simple upgrade wihtout adding amps new wiring ect The other option is replacing the stock head unit |
so how much of a louder thump will this be for the C6Z?
Originally Posted by seung012
(Post 1579154830)
you would need something different for that:cheers: |
ttt
thanks everyone!
Do u have the same size as the front speakers ?
Originally Posted by carloscaneja
(Post 1579160503)
The 3.5 is the same size You wont be able to replace anything else without more work and adding a harness and amps We canpackage that together for you if you like just let me know Dennis |
thanks everyone!
Do these work with the Bose, XM, nav radio?
Originally Posted by fast_fred
(Post 1579164811)
Any and all options:thumbs::cheers: |
