63 AM/FM radio repair question
The AM/FM radio in my '63 makes a loud scratching sound when powering on or adjusting the volume knob. Can anyone suggest a repair service?
Also, does the glove box need to come out in order to remove the radio? TIA |
Todds Electronics in MO always have an ad in the NCRS Driveline. Been doing repairs for over 50 years on Delco radios.
314-277-9333 or 636-926-2267 |
Originally Posted by rdc
(Post 1579163485)
Also, does the glove box need to come out in order to remove the radio? TIA No you do not need to remove the glove box. Just the 2 radio side panels. For some reason the radio seems to come out the drivers side easier or at least it's that way for me:D |
:iagree:
Originally Posted by ratmotortom
(Post 1579163559)
314-277-9333 or 636-926-2267 Todd is who I use.:thumbs: |
Thanks for the replies!
(Post 1579163485)
You might have to remove the radio to gain physical access to the volume control, but you can almost certainly save the cost of a repair bill if you will do this yourself. Jim |
:iagree:
It's caused by dust or corrosion on the wiper of the volume control. It has an opening just behind where the wires attach to the volume portion of the control. Spray some contact or tuner cleaner into that opening and move the volume up and down rapidly to clean the contacts. You can also disconnect the battery and run the volume up and down multiple times and get it much quieter, but not as good as using cleaner. A little spray will do you. |
Originally Posted by 65GGvert
(Post 1579164965)
:iagree:
It's caused by dust or corrosion on the wiper of the volume control. It has an opening just behind where the wires attach to the volume portion of the control. Spray some contact or tuner cleaner into that opening and move the volume up and down rapidly to clean the contacts. You can also disconnect the battery and run the volume up and down multiple times and get it much quieter, but not as good as using cleaner. A little spray will do you. You saved me about $200! Where do I send your commission? :o |
(Post 1579167644)
To my surprise, turning on and off plus running the volume up and down multiple times was a quick fix! I will take the time at a later date (good rainy Saturday project) to pull the radio and spray contact cleaner on the wiper area.
(Post 1579167644)
(Post 1579167644)
You saved me about $200! Where do I send your commission? :o Roger |
Originally Posted by 63atlast
(Post 1579169193)
Glad you got it working. If you ever do need a radio repair there is a guy in Chattanooga, TN that I have used a couple of times. Does excellent work, reasonably quick turn around, reasonable prices. He has the AM/FM out of my '63 right now. Gene Edwards (423) 877-9910. Good luck.
Roger Thanks for the info. From the phone number, sounds like Gene is in the Hixson area...I'm originally from Chattanooga and visit often (now in Mt. Juliet). Dennis |
radio noise (volume control)
I have posted good results solving problem on my 63 swc with am radio. Volume control noIsy on opening radio, volume increases, etc. Pull off the volume shaft knob.Turn on radio, with a small hammer, give the end of the volume shaft a sharp rap . This caused control to work properly. Probably a poor ground.NO RESPONSIBILITY ON MY PART ! Confirmed works by several members. Regards, Abe G
