Has anyone done a T56 to T6060 swap?
If so, what else was involved or was it a direct bolt in replacement?
Originally Posted by HeyDanNiceShot
(Post 1579379295)
I'm actually in a bit of an interesting situation. My transmission is being replaced under warranty on my '07, but it's totally out of stock at GM until January or February. What I'm wondering is, can I simply tell them to order the TR6060, and I'll pay the difference? My bet is as long as I covered the cost difference, they'd do it without hesitation.
(Post 1579379991)
Thanks! I appreciate the advice!
Originally Posted by Rick@RKT56
(Post 1579380075)
Have them order you a TR6060 from a 2008 and it will be a bolt in.
If you are retrofitting the T6060 to a T56 equipped Z06, the different oil cooler connection is one hassle you'd like to avoid, thus the recommendation for a 08 spec T6060 (of course if they don't have T56's available, they probably don't have 08 T6060's either. |
tans swap
Call RPM Transmissions,they will set you up,also have the option to change ratios,mainly 5th gear.Also their level 6 is super tough,and super smooth.It was a direct bolt in,couldn't be happier!
You will be getting a better transmission as well. All you need is the one tube that goes between the transmission and the rear diff oil cooler. I installed a ZR1 TR6060 into my Z and it was a direct bolt in.
