Question about where to get parts for a '78 HEI Distributor
I got a wild hair you know where to go out and tinker with my '78 L-48 car so I found a set of Mr. Gasket advance curve springs and set my timing according to the paper. My issue was that the pivot bushings for the stock weights were not reusable so I installed the weights (which feel much lighter than stock) and bushings included with the Mr. Gasket kit with the light springs and get 36 degrees of advance at about 3600rpm, instead of 2500 - 2800 rpm.
So.. Where in the world do buy replacement bushings for the original equipment? Every place I have book marked sells the Mr Gasket/MSD/Spectre advance curve kits and google isn't being friendly. Any help is appreciated!! |
I'd be interested too. Never was able to find the originals that fit. Always the bigger ones that they sell with the kits that don't fit original weights.
Finally had some luck..
Advance auto parts sells them: Link to Advance part# I found this because it's been hashed out a time or two here... |
I have a NAPA store near me, I was going to offer to get them for you since you could not order them, Then I'd mail them to ya. Let me know if you can't get them at your local store. THANKS for finding them.
I ordered the ones from Advance.. but thanks for the offer!
Originally Posted by pancake
(Post 1579439661)
Originally Posted by ben dover
(Post 1579441168)
Let us know if they fit/work.
I just went to advance, and called Napa. Both said this item was not in stock, and they could not order it. Believe that! Napa advised me to go directly to a GM Dealership/Stealership........ Urghhhh..
dist bushings
DG13 is a borg warner number called oreillys and they have them.dont know if they fit? ill bet they do:woohoo:
Originally Posted by daanbc
(Post 1579451857)
(Post 1579455912)
Hmm.. I ordered them from Advance and just received an email that they shipped it. I should have them in a few days and will let you know if they're the right ones.
You could just throw your 78 dist away and buy the ebay $54 dist and call it a day.
Originally Posted by Tim H
(Post 1579456227)
(Post 1579456227)
(Post 1579456227)
And cheap too, which is just how I like my wimen :thumbs: |
(Post 1579456268)
I just received a 77 dizzy that LARS performed work on.
The ebay dist has a brass insert cap, 65000 volt coil, a timing curve from hell, and a polished housing all for $54. My timing with one is 15 unplugged, and 36 plugged to full vacuum which equals 51 total. |
company been around forever
standard ignition aka standard motor products. phone your local parts houses & ask who sells brand "standard ignition" smpcorp.com ecatalog has parts for either points or hei ... & MUCH more ... pick your year etc http://www.standardbrand.com/Online%...g/Content.aspx |
(Post 1579439066)
(Post 1579457910)
What can he possibly do to a dist that takes more than 5 mins?
