C5 Brake Part Numbers?
Im about to do the front brake upgrade but need the part numbers for the guide pins as well as any hardware Ill need. I found the anti rattle clips on autozones website but theyve also got 3-4 part numbers for the guide pins.
Originally Posted by armybyrd
(Post 1579493386)
This is all the info I have hope it helps you. :cheers: Calipers Part Number Description Price 12530682 Reg C5 Caliper - RH $100.80 12530683 Reg C5 Caliper - LH $100.80 88895129 Z06 C5 Caliper - RH $97.65 88895128 Z06 C5 Caliper - LH $97.65 Rotors Part Number Description Price 10445857 C5 Rotor - LH $55.83 10445856 C5 Rotor - RH $55.83 88926732 C5 Rotor - LH (Durastop Performance) $44.40 88926731 C5 Rotor - RH (Durastop Performance) $44.40 Caliper Brackets Part Number Description Price 12455799 Caliper Brkt - 2 required $31.67 Misc Parts Part Number Description Price 12530697 Caliper Guide Pin (4 reqd.) $3.95 12530703 Caliper Guide Pin Seals (4 reqd.) $3.30 10139097 Brake Hose Gasket (Copper Washer - 2 per caliper) $0.42 12530681 C5 Brake Pads $65.87 88909667 C5 Ceramic Durastop Pads $54.87 *Prices current as of 1/04/02 Here's the parts required list I've put together (don't forget you'll also need the non-GM special bracket kit): C5 Brakes on C4 Qty Needed P/N Description 2 12455799 Caliper Bracket 1 88895129 -or- 12530682 Caliper 1 88895128 -or- 12530683 Caliper 1 10445856 Rotor 1 10445857 Rotor 4 10139097 Hose Gasket 4 12530697 Pin 4 12530703 Seal 1 12530681 -or- 88909667 (Or Non-OEM) Pad Kit http://forums.corvetteforum.com/atta...1&d=1324096228 |
Anyone happen to know what the equivalent part number thru autozone would be for the guide pins?
http://www.autozone.com/autozone/par.../N-jleodZ8knjf |
If you get new calipers from Gene Culley at GMPartsHouse, the caliper assembly will come with guide pins and bolts, rubber seals, and the anti-rattle clips (these are only used for stock GM pads).
It's hard to say why AutoZone is listing 4 different guide pins. But the pins for the front calipers are different than the rear calipers. Their p/n 14150 is clearly marked "Rear" so those would be out. You may want to send a PM to Gene Culley to see if he will mail to an APO address, If he can do that, it would be much easier than trying to ID the correct AutoZone parts. Also note that in other than color, there is no difference between the front Z06 caliper and the "regular" C5 front caliper. |
Thanks for the info guys. Might do this conversion on my car soon. :cheers:
x2, thanks for the info, respectfully.
There are some very cool people on this board. Thanks for sharing your knowledge.
also much thanks for the added input. So just to be clear the anti-rattle clips are only for stock GM brake pads?
(Post 1579504588)
alright-thanks again for the added input. Just about finished painting the front calipers.
Originally Posted by mako41
(Post 1579513233)
No, I used all three (per caliper) anti rattle clips when I did this upgrade with the Hawk HPS pads I installed. The anti rattle clips, (part#10, 1 pair/caliper, in the illustration posted above by PLRX, come with the purchase of new OEM GM brake pads. Most people reuse these clips when they replace worn brake pads. There is also an anti rattle clip, (part#6 in the illustration above, 1/caliper), that comes with the OEM GM ZO6 calipers when bought new. I used all of these clips, 6 total with the Hawk HPS pads. :thumbs:
Anyone have the part number for this part? |
