Need a GOOD alternative to Headlight bumpers DS Headlight not coming up
Guys, I need some help. I've got an '02 vert and I've read just about every post on here about headlight problems. I've replaced two headlight gears and have done a lot of troubleshooting on these headlights. The chronic problem I'm having is that my DS Headlight doesn't come up when I turn the lights on. I know WHY: the down stop/insulator is worn and the headlight is going down too far and overtightening the manual turn knob. 1 quarter-turn and the knob loosens and the light comes up on the next try. It works until the next time it goes down and over-tightens. What I don't know is HOW to fix the problem!
Part #16524060 (the insulator) is known to be discontinued. I've tried flipping over my worn insulators and it failed within days! Here are the other things I've tried in place of them: -Rubber Gas Line Hose - too soft, got torn to pieces -Hard Rubber Bushings - longer-term fix, but still gets eaten up over time and is too bulky and gets in the way of the actuator arm. Anybody having as much trouble as me because I can not get a good fix to this issue?! I'm thinking of trying to pad the actuator arm that comes down so hard on that tab stop next. Maybe this would be the best option?? Any insight is much appreciated! |
Ecklers has repo
You can order from Ecklers
http://www.ecklerscorvette.com/corve...1997-2004.html Corvette Headlight Stop Bumper, 1997-2004
Originally Posted by ICUALL
(Post 1579627193)
Yeah, I've got 8 of these on order; should arrive on Wednesday. However, Rodney Dickman has told me that these are too brittle and did not work well. We'll see. Any other ideas out there to (almost) permanently solve this problem? |
Originally Posted by ryrob
(Post 1579630686)
Any other ideas out there to (almost) permanently solve this problem? Got the stops from Ecklers today. When I pulled out the original that I had flipped over last week, I was shocked to see that in 7 days that acuator arm had put a big-time dent in this insulator. 7 days! I don't know how these things lasted all this time in the first place. Anyway, when I tried to put Eckler's reproduction stop on the down stop tab, it wouldn't even fit all the way on the tab. I had to drill it out a little bit so it would fit on. I've got one of Eckler's stops on a down tab and one on an up tab, so we'll see how they do. Not holding my breath... Are my actuator arms just brutal or what?!? :confused2: |
Make sure the arm will hit the metal tab when the stop is removed. If not, put washers between the motor and the bracket until the arm does hit.
Peter |
Originally Posted by lionelhutz
(Post 1579646597)
Peter Thanks Peter, yeah I did the TSB fix on that driver's side when I replaced the gear in the motor. The arm lines up to the tab great. It just must come down with such force that it eats these things up. I'm thinking of padding the arm next so it will dampen the force. Am I the only one having such a chronic problem with this issue? :banghead: |
The headlight controller sets the force. It's possible your controller is simply bad and not stopping until it applies too much current to the motors which means too much torque.
Peter |
(Post 1579648509)
Peter |
(Post 1579648509)
Peter The HLCM is the ONLY thing that has an effect on that function. What is your C5 SLEEP Current draw at the main 12 VDC battery?? When the BCM is in the SLEEP mode, part of the 20ma current draw is the BCM, and that module keping the headlight motors torqued shut my keeping that module powered up. Bill |
(Post 1579648509)
Peter
Originally Posted by lucky131969
(Post 1579652555)
Good point Peter. Since the problem is isolated to the drivers side, perhaps it's time to measure the current draw on the drivers motor, using the passenger side as a comparison.
Originally Posted by Bill Curlee
(Post 1579652605)
:iagree: 100% ACCURATE! I also recommend changing out the headlight control module. Not only is too much torque messing up your stops,, its going to cause motor/gear failure and excessive wear on the head light assy movement points. You can put an amp meter in series with the head light motor power wire and see how much current its drawing compared to another C5 that isnt tearing up the stops. I do not know what the "IDEAL" designed current cut off is but its not very much. Listen to your head light into the stops sound compared to another C5. See if it sounds like it hammering home too hard thats an issue.
The HLCM is the ONLY thing that has an effect on that function. What is your C5 SLEEP Current draw at the main 12 VDC battery?? When the BCM is in the SLEEP mode, part of the 20ma current draw is the BCM, and that module keping the headlight motors torqued shut my keeping that module powered up. Bill Thanks so much for the input guys! It's a good lesson for me - find the actual Cause of the problem before spending so much time on the Effect. I've got a new HL control module on order, so I will post again when I get it installed. Fingers crossed! |
The new HLCM has arrived. The repair procedure for replacing this part is telling me to go in from under the car. Is this completely necessary? I'd rather get to it from the headlight assembly if possible. Thoughts?
Ryan |
(Post 1579726444)
Ryan This is the manner in which I replace burned out DRL/turn signal bulbs. HTH |
Originally Posted by LoneStarFRC
(Post 1579727028)
For safety, unplug the power connector to motor assembly immediately behind headlight, manually raise your headlight to the up position, remove your RH headlight close-out panel (black), then (measure height first) remove the RH hood-stop with the rubber pad on top. You should then have enough room to reach down inside, unplug the module and remove it's mounting fasteners.
This is the manner in which I replace burned out DRL/turn signal bulbs. HTH Now, I inspected the old control module and the only suspicious-looking thing was the one of the corners of the back cover had come loose. The inside looked OK, no obvious damage to the circuit board... Never was able to test the current that the old module was sending out to the HL motors however. Well, the new one is in and I have turned over the insulators to a fresh side. The only thing to do now is wait and see if this new HLCM is the answer that I've been looking for! |
To post pictures on here you must first upload them to another site such as photobucket, you cant link them directly to your computer.
Originally Posted by m6 c5
(Post 1579752722)
These are pics of the old headlight control module that we think is bad... http://i1247.photobucket.com/albums/...9/SDC11144.jpg http://i1247.photobucket.com/albums/...9/SDC11149.jpg http://i1247.photobucket.com/albums/...9/SDC11145.jpg |
It does look OK but that still doesn't mean it's working correctly. Here's hoping the new one works for you.
I read about some cars stripping gears within 20k or 30k miles and others running 100k+ miles before gear failure. So, there must be a range of motor currents and switching times on these modules and the ones prone to failure drive the motors too hard. Peter |
(Post 1579762856)
I read about some cars stripping gears within 20k or 30k miles and others running 100k+ miles before gear failure. So, there must be a range of motor currents and switching times on these modules and the ones prone to failure drive the motors too hard. Peter http://i1247.photobucket.com/albums/...9/IMAG0136.jpg http://i1247.photobucket.com/albums/...9/IMAG0134.jpg So in just one day this is the indentation done by the arms. The interesting thing is that the indentation is about the same on both tabs; HOWEVER the passenger side always comes up. It's the DS only that gets stuck. The same amount of indentation in the tabs is what puzzles me. What's the next step if the DS headlight continues to get stuck? Could it be that the motor is just bad and needs to be replaced. The big key is that the manual knob is just being overtightened on the DS, I just don't know why. :banghead: |
Headlights have been popping up fine for the last two weeks, no problems. I was ready to declare that the Headlamp Control Module was the solution to the problem. However, last night something strange happened:
I went to turn the lights on, flipped the headlight switch and NOTHING happened. Hmm. Turned it back off and flipped it on again and the Driver's Side headlight only came up. Those of you that have read the whole thread know that this is the exact OPPOSITE of the original issue (only PS came up before). I had to get out of the car, turn the manual knob a quarter turn and everything worked after that. Now I'm a little confused. What could this be if now the DS comes up and the PS doesn't?? Brand new HLCM had been working fine... |
(Post 1579626652)
Part #16524060 (the insulator) is known to be discontinued. I've tried flipping over my worn insulators and it failed within days! Here are the other things I've tried in place of them: -Rubber Gas Line Hose - too soft, got torn to pieces -Hard Rubber Bushings - longer-term fix, but still gets eaten up over time and is too bulky and gets in the way of the actuator arm. Anybody having as much trouble as me because I can not get a good fix to this issue?! I'm thinking of trying to pad the actuator arm that comes down so hard on that tab stop next. Maybe this would be the best option?? Any insight is much appreciated! I replaced the gear with the bronze one with the rubber insert and the only change I got was a major increase in gear noise. Thanks for the updates. |
Did you use the solid brass gear or the one with the rubber insert?
Peter |
