Auto Swap Thread
7 Attachment(s)
Well some parts came in today and its about time to get it back together. Auto swap in my 01 Z06.
Level VII RPM 4L65/70E transmission, with billet input, billet pump rotor, and billet 300M output shaft, SFI Bellhousing, deep pan, Transbrake DSS 3.5 in. Driveshaft DSS Urethane couplers Corvette SFI flexplate Cone for Auto flexplate assembly Coan Converter Shifter assembly and shifter cable Auto Torque Tube PCS TCM-2000 controller and wiring harness Im posting this for people thinking of doing the swap and for yall to double check my work, make sure i do everything right. :cheers: Lets get started car all torn apart Attachment 48149478 New Tranny Attachment 48149479 Attachment 48149480 Attachment 48149481 Flexplate Attachment 48149482 Lots of wiring Attachment 48149483 PCS Tranny Controller Attachment 48149484 |
Auto Z06! Sweet, this is going to be a good thread!
Nice choice in parts, looking forward to the finished product! :cheers: |
Originally Posted by Blitzkrieg
(Post 1579668375)
I did my 1st one about 4 or 5 years ago before RPM was selling the conversion harness. I took a 04 Z06 and a 01 auto Vette and converted the Z06 to auto and the auto vette to 6 spd. Since then I have done several more. Not bad once you do the 1st one. I used the factory ECM to control the trans on the ones I have done.
Good luck Kris |
1 Attachment(s)
Thanks guys
chris did u use the 6sp brake pedal. somebody told me i needed to get an auto brake pedal if i wanted cruise to work is that right? Or can i just take off the clutch part? |
Yes I still run the 6spd brake pedal, it saves the hassle if I switch back. I pulled the clutch pedal assembly and covered the hole in the firewall. The original cruise control cancel switch is still in place on the brake pedal. I'm also using the factory computer to control the trans. Might save you some $$$ to return it. I was told I would need a stand alone controller for a 4L80.
Originally Posted by Chris Stewart
(Post 1579670877)
Sweet! Subscribed
Don't forget to zip tie the switch or permanently connect your clutch switch wires before you bother trying to start your car.
Take lots of pictures so dummies like me can figure it out if and when I have a total breakdown and decide to go auto. |
Originally Posted by BLOWNBLUEZ06
(Post 1579671116)
Been awhile since I had to mess with the stock trans & rear.
As I recall there's a spacer/plate between the rear & auto trans, unlike the manual trans?? |
(Post 1579671116)
Originally Posted by 4DRUSH
(Post 1579671550)
Originally Posted by 02402ramair
(Post 1579673426)
The auto trans uses a seal plate that slides in the diff. This is only used on the auto
seal plate parts num plate 12369457 list=42.76 seal 24207010 list=10.96 O-ring 12369456 list=8.88 |
I think the plate is part 12369457 and needs an o-ring. Found a pic here, halfway down the page:
http://tim-yvonne.com/mikemercury/342.htm |
how much have u spent so far on the swap?
Originally Posted by corvette8189
(Post 1579667850)
and where can I buy a pair of those pink jack stands? |
This i like :thumbs:
iŽll be watching this threat :lurk: good luck Baezi |
When I did my auto conversion it was a PITA but was best mod I done. You will love dragging Bret down the interstate in Mexico. lol Auto for the win.
