Looking for a X pipe dual exhaust system for a 77
Here is what I have found close to what I am looking for in a complete kit.
http://www.parts123.com/parts123/yb....5Z5Z50000050Q# I am looking for headers to an X pipe to dual pipes to the mufflers that come in a kit. Does anyone know of a good place to buy a bolt in system, or if what I found is the best option with getting an X pipe and working it into this. Or is the X pipe not going to make a difference? Just seeing what everyone else has ran and what seems to be the best option. Thanks |
Your link doesnt work
Here are some systems from PYPES http://www.summitracing.com/search/Y...?Ns=Rank%7cAsc |
I know one setup that has been used is Flowtech BIG-31106FLT headers to Hedman HED-18804 pipes to SUM-642125 X Pipe, all from Summit. Then you need some 45's and some straight pipe to go to mufflers.
With a quality set of headers... I would not think that a X pipe would do much more than equalize the exhaust sound..My 77 has custom bent tubing with the Walker band clamps from a local Exhaust Shop....spent around $200.00 . Plus the cost of the mufflers....
Magnaflow 16710. Should look similar to the 16842 system without the front pipes. Shop around and you can buy it for a lot less than MSRP.
:cheers: Rick B. |
I made some calls around and it seems MUCH cheaper to buy a decent set of headers, install them, rip out all the old exhaust, and then take it to a local muffler shop and have them do it all custom. Not to mention it will all be welded and I will not have to spend hours making a "made to fit" system actually fit. I do really appreciate all the advice and am looking at the options for the mufflers. Liking the Magnaflows so far.
Originally Posted by Sideways73
(Post 1579763774)
My home made mandrel bent exhaust with X-pipe and Magnaflow mufflers. |
I bought the complete 2.5" Magnaflow system from Amazon for around $525 shipped.
John |
I bought the complete stainless big block 2-1/2 inch magnaflow system with x pipe for $495 shipped on ebay. From the crossmember back it would be the same for bb or sb. I cut up the head pipes to to fabricate header connections. This item also comes with all stainless clamps and hangers and is all mandrel bent.
