C6 Z06 Big Brake Kit- Free Shipping
C6 Z06 Big Brake Kit-from $2099 Free Shipping
Choose from Yellow, Red, Silver or Charcoal. 0% Financing available for up to 12 months! Now you can have the awesome brakes big brakes of the C6 Z06 for your C5 or C6 @ a smoking price! This great kit has everything you'll need to bolt them on your C5 or C6! This kit features large 6 piston front calipers with 355mm x 32mm (14" x 1.3") rotors and 4 piston rear calipers with 340mm x 26mm (13.4" x 1") rotors. Calipers are NEW factory GM parts and TPS Zinc Coated Rotors, OEM Brake Pads, Motul Brake Fluid and TPS DOT approved stainless steel brake lines. This is a direct bolt on system and comes complete with all needed parts to complete your installation. Our TPS Zinc Coated rotors prevent rusting on the hats and veins of the rotors Please Note: If you are installing these on a C5 you will have to run at least 18x10.5 C5 Z06 Wheels in the front to have proper wheel to brake clearance. If you have aftermarket wheels and are unsure if they will fit these brakes please contact me at Mikem@TPSMotorsports.com and I will email you a wheel template so you can confirm the brakes will fit your wheels. Kit includes: * (2) 6 Piston Front Calipers * (2) 4 Piston Rear Calipers * (2) TPS Zinc Coated 14 inch Front Cross Drilled Rotors * (2) TPS Zinc Coated 13.4 inch Rear Cross Drilled Rotors * (1) Front and Rear Brake Pads * (4) TPS DOT Steel Braided Brake Lines. * (3) Pints Motul Racing Brake Fluid. Brake Pad Options * Centric Ceramic Pads * Hawk HPS Brake Pads (1 Piece Design) * Hawk HP Plus Brake Pads (1 Piece Design) https://cimg1.ibsrv.net/gimg/www.cor...ad9a05143e.jpg https://cimg3.ibsrv.net/gimg/www.cor...87ad917412.jpg https://cimg5.ibsrv.net/gimg/www.cor...204dd6987b.jpg https://cimg6.ibsrv.net/gimg/www.cor...02b9c87a13.jpg |
Will these fit behind the stock 2008 Gumby wheels?
Originally Posted by TJay74
(Post 1579829877)
How thick of a spacer and will it require longer studs?
(Post 1579834967)
Here's some pictures and a thread about the wheels http://forums.corvetteforum.com/c6-c...akes-pics.html http://i171.photobucket.com/albums/u...e/P1010420.jpg http://i171.photobucket.com/albums/u...e/P1010415.jpg http://i171.photobucket.com/albums/u...e/P1010417.jpg http://i171.photobucket.com/albums/u...e/P1010416.jpg http://i171.photobucket.com/albums/u...e/P1010419.jpg |
We can powder coat them any color you want also.
Here is a sample of a set we did in Candy Blue http://www.tpsmotorsports.com/media/...c/b/cbz063.jpg http://www.tpsmotorsports.com/media/...c/b/cbz066.jpg |
For this month only.. we've offering a trade in program for your old used braking system for ANY C5, C6, or C6Z.... PM to find out more details
PLUS 0% financing is available for all TPS C6Z Brake kits! |
Are you looking for a set of C6 Z06 Brakes to upgrade your Vette? Check out our C6 Z06 Big Brake Kit for your C5 & C6! Choose from Red, Yellow, Charcoal, or Silver Calipers!
0% Financing is available for up to 1 year :) If you don't like the colors we have we can customize the color to ANYTHING you like an extra $599. https://cimg9.ibsrv.net/gimg/www.cor...eb8f9d02fa.jpg https://cimg6.ibsrv.net/gimg/www.cor...26d76fe002.jpg https://cimg8.ibsrv.net/gimg/www.cor...bd5b901eb0.jpg |
Thanks for all the orders! In stock and ready to ship!
BEST BIG BRAKE KIT DEAL FOR AVAILABLE! -Everything is included in your kit for a complete install! 0% Financing for up to 1 Year Available! https://cimg7.ibsrv.net/gimg/www.cor...c16eee64dd.jpg |
Looking for a Big Brake Kit for your Vette? TPS carries big brake kits from Baer, Stoptech, Wilwood, and C6 Z06 starting from only $750 per axle!
0% Financing for up to 1 Year Available! |
