Ridiculous 60'
Originally Posted by carlrx7
(Post 1579995711)
SICK!!!!! Joe! Congrats!
Originally Posted by dennis50nj
(Post 1579995913)
:party::party:way to go Joe:cheers:
Originally Posted by CDaniel525
(Post 1579996607)
Wow, thats killer on a stock clutch'd ls2!! Congrats Joe!
Im gonna need some serious practice to get anywhere near that 60' time! LoL
Originally Posted by RapidRick
(Post 1579996662)
"Holy Smokes".......:eek:
Absolutely fantabulous Doc Sparky! :cheers: :woohoo: :flag:
Originally Posted by HOXXOH
(Post 1579996714)
WOW! 1.44 and even twice. :thumbs:
Congrats on the PB 10.81. :rock:
Originally Posted by dsp300c
(Post 1579997481)
congrats!!!! :rock:
Originally Posted by matt_lowry123
(Post 1579998317)
Damn that's fast!!! Good job dude!!
Originally Posted by taken19
(Post 1579998553)
Great job Joe!!!
When Justin throws in the towel for a new clutch, maybe we can have a clutch party...
Originally Posted by Fly'n Family
(Post 1579999106)
Holy smokes..............1.44's? That's amazing - congrats! :thumbs:
Originally Posted by dicky
(Post 1580000104)
wow congrats joe, i didnt even know they were open yesterday. if i would have had my exhaust on i would have been up set i missed it. i should have my exhaust fixed in a week or so then ill proably go out again before i leave for cali.
Originally Posted by FloydSummerOf68
(Post 1580000727)
Ridiculous 60'
I have to say, my clutch is one reliable piece of machinery. I just drove it for an hour in stop and go traffic on i-95...creeping along...it's just like a Honda Civic clutch in traffic. Yet it'll hold a 6700 RPM 100% throttle launch, matter of fact, two of them within 4 minutes. Roger Preston of Horsepower Sales and I were just laughing about it this morning. I'm not sure how I got so lucky with that clutch. I tell all my friends that God loves me and it's true.:yesnod: |
Originally Posted by Justinjor
(Post 1580000250)
I'm optimistic that this clutch will hold on for awhile longer. I've identified the issue I was having and have adjusted to make sure it doesn't happen again. IF I do in fact have to put one in, a clutch party sounds like a good time to me. :cheers:
Joe_G... Have you done anything to your clutch system to make it last soo long, other than say Ranger fluid flushes?? |
(Post 1580001037)
What was the issue you were having with your clutch Justin... how did you remedy it...
Joe_G... Have you done anything to your clutch system to make it last soo long, other than say Ranger fluid flushes?? 1) Removed the clutch spring. Well, Joe removed it the first time we met at PBIR, but ya-it's gone. 2) Removed the inspection plates on the bellhousing. The problem with the corvette hydraulics is that the clutch dust has nowhere to go when it is generated and it then penetrates the vulnerable slave cylinder which is why the fluid turns black. To assist the clutch dust from exiting, I removed the 2 plastic inspection ports on the lower sides of the bellhousing. I did this a few months ago and my clutch fluid has been remarkably clean ever since. I still do the fluid swap, but what used to take 3 or 4 cycles of clean fluid to 'repair', now only take 1 cycle. 3) My burnouts are now only 3-4 seconds. I used to do longer smokier burnouts to get my Toyo drag radials hot, but these Mickeys don't take much to get them ready. I also swap the fluid before and after the drag strip as Joe recommended to me awhile ago. I don't expect to get 450+ passes on it, but I'm knocking on the door to the 150+ pass, 70+ of which have been with the cam installed. Hope that helps. Big thanks again to Joe for his invaluable information he has so graciously shared with me. Thanks buddy :cheers: |
I do the Ranger method before and after each event religiously since new. The fluid is pretty much always clean, even yesterday evening after those events.
Removed pedal spring as soon as I put in a cam. It was sticking to the floor after the cam (but not with only bolt ons). I don't think my car has anything plugging the inspection ports on the bell housing, I've seen tracks of clutch dust on the bell housing. Check out the clutch dust on the video! My buddy said it looks like a pro stocker belching out dust. :lol: |
I've lost count of the pedal spring-ecotmies I've done at the track. Two or three in the last couple of months.
Originally Posted by Joe_G
(Post 1580001148)
Removed pedal spring as soon as I put in a cam. It was sticking to the floor after the cam (but not with only bolt ons). I don't think my car has anything plugging the inspection ports on the bell housing, I've seen tracks of clutch dust on the bell housing. Check out the clutch dust on the video! My buddy said it looks like a pro stocker belching out dust. :lol: That's interesting Joe. I think I may have misphrased that--not the inspection ports, the 2 plastic 'covers' on either side of the front of the bellhousing. The starter goes through one of them, and the other side is just attached with 2 10mm bolts. Removing them lets a nice amount of air flow through the bellhousing and out the 2 inspection ports which should help with dust exit. At least, that made sense to me. |
(Post 1580001153)
(Post 1580001165)
Removing them lets a nice amount of air flow through the bellhousing and out the 2 inspection ports which should help with dust exit. At least, that made sense to me. Jeremy Formato did a nice post on it. http://forums.corvetteforum.com/c6-t...ur-clutch.html |
(Post 1580001195)
I've not done the mod to remove the front inspection plates. I hate crawling under the car on stands. Easy to do or a pain?
Jeremy Formato did a nice post on it. http://forums.corvetteforum.com/c6-t...ur-clutch.html Removing the starter-side one is a huge pain. I actually had to loosen the passenger side header so I could wiggle the starter far enough to clear the inspection plate. It's a little piece of plastic but it certainly gave me hell. :lol: |
Congrats Joe! 1.44 is insane on a stock clutch, I can't wait to see pics of it if you ever take it out! Must have magic ferry dust sprinkled on it lol For sure would have been a 10.7 without the head wind, but don't suppose you can complain too much as that's a nice DA with the sun out:thumbs:
(Post 1579995994)
Hm--that sounds like a challenge Marc :D
Originally Posted by PRE-Z06
(Post 1580001222)
I believe it'd be possible for you with a gear swap as your coupe is lighter:thumbs: I was hoping to get close to Andrew and Dennis but alas, seems it's not going to happen as I'm done beating on my car that gets me to and from work. I hadn't planned for a track event, so I had almost 3/4 of a tank. I went to siphon out some gas (which I've done before) but couldn't find my 1/8 plastic line. 1/4 plastic line doesn't work BTW, but 1/8 does, just takes a while to do it. I did drive up in 5th to burn off some gas. Al Gore would not be proud. I did siphon out my washer fluid, and used the opportunity to show my 6 year old a little bit of science in the form of pressure differential via the siphon technique. He was non-plussed and preferred to do battle against aliens on his Wii. I didn't push the issue as I realized I really didn't want him getting a mouthful of gas like I did the first time I did it, but perhaps he noted the technique of how to NOT get a mouthful of gas which is what I was trying to show him. My wife's plan is better, don't try to siphon gas. But hey, if the world goes to Mad Max I'm your man. I can do lots of things like siphon gas.:lol: |
:lol: Joe, you crack me up.
Done beating on your car though? Say it ain't so! I can't believe you're done with the dragstrip. . . |
(Post 1580001387)
Done beating on your car though? Say it ain't so! I can't believe you're done with the dragstrip. . . I'm looking forward to our new challenge series starting 3/17. But there's a huge difference bracket racing your car, dialing soft and launching easy, going for a good light and working the stripe, vs. launching at 100% throttle and 6700 RPM! You can bracket race a car, dialing high 11's and launching for a 1.8 60 foot, for a long time. You only get so many 1.5 60 foots, and I think the 1.44's count double against rear end life! |
(Post 1580001433)
Oh I didn't say that!:willy:
I'm looking forward to our new challenge series starting 3/17. But there's a huge difference bracket racing your car, dialing soft and launching easy, going for a good light and working the stripe, vs. launching at 100% throttle and 6700 RPM! You can bracket race a car, dialing high 11's and launching for a 1.8 60 foot, for a long time. You only get so many 1.5 60 foots, and I think the 1.44's count double against rear end life! I'm trying to get the #1 spot for LS3 internal mods as the car sits right now and I'll get there with your help :thumbs: |
What tires and sizes are you using in the rear?
Originally Posted by danieloneil01
(Post 1580001473)
They rub on standard c6 fenders, not so on z06/grand sport fenders. |
Congrats Joe! :thumbs:
What's she weighing in at these days? |
(Post 1580000250)
What's wrong with your exhaust? Or did you get something new?
Nice time Joe and killer 60' :thumbs:
