Rattling noise
I just started noticed a rattling noise from the driver's side rear on my 92. It seems to happen between 45 - 55 mph. I can feel it in my left foot when it's resting flat on the floor of the car. Any ideas? Is it maybe a wheel bearing?
could be a number of things, loose brake caliper, bearing would be while turning you would hear it better, exhaust is loose, spare tire ect..
Originally Posted by derekguzz
(Post 1580090272)
swaybar link bushing.
Originally Posted by kimmer
(Post 1580091506)
(Post 1580091506)
Otherwise, as above a rattle could be loose exhaust, spare tire, etc... If you want to test the sway bar, you can either remove the rear wheels, or just on the ground have someone push down on the rear of the car while you shine a flashlight through the wheel to observe the rear sway bar link and see if it moves around. |
Originally Posted by dailo
(Post 1580092207)
Agree, had the same problem where either the road was bumpy enough to make the car bounce around a little, or the speed was enough where slight bumps made the car bounce. Sounds like a metallic tink tink, its the sway bar bushing.
OK. So I checked the exhaust, spare tire, and calipers and don't see where anything is loose. It is an intermittent noise and I can't duplicate it. This is going to drive me nuts.
Any other suggestions? |
Do you have cats on the car? Maybe one is broken internally. Do they have heat sheilds on them??
I do have the cats on. Wouldn't a broken cat throw a check engine light?
Don't know about the heat shields. What are you thinking there? |
any bushing can be bad,first to go is the dogbone bushings. easy visual check. pull the back wheel. if the mounting bolt does not appear dead center in dogbone your bushing are shot.. you can also use a small pry bar to move them around to check. easy fix. good luck
Will check that. Thanks,
Originally Posted by ggroller
(Post 1580125430)
loose lower shock nut.
Originally Posted by PLRX
(Post 1580132713)
did cha find the problem?
Originally Posted by midweekwarrior
(Post 1580193338)
Here's the kicker. I drove the car about 20 miles last Friday and it didn't make the noise at all. |
I had a rattle in the left rear also. Took it to my mechanic and we narrowed it down to a loose baffle in the muffler. Replaced the muffler and the rattle went away.
Drove 10 miles to work this morning. Again, no rattle. WTF???????
Okay, so imma tell my story now.... I replaced the optispark on my vette, and i forgot a socket that somehow managed to get into the area driver side between the engine bracket/chasis thing and the fender well... rattled constantly for about 3 weeks until i gave up and noticed it being shiny one afternoon when i was changing the oil.
Moral of the story.... not all noises are problems, some come and go and i attribute them to the mechanic gnomes |
