Oiled air filters
I have used oiled air filters for years and i noticed that if you clean the mass air sensor about every 60 days the throttle response is much better. Also if you do not have a PCV catch can you may need to remove the throttle body and clean the oil out of the intake manifold at least every 6 months to a year. I just cleaned mine and was surprised at how much oil was in the intake.
Originally Posted by sledmaster
(Post 1580100502)
(Post 1580100502)
I am still up in the air on the catch can. |
Even if you are using the stock paper filter you still will get better throttle response when you clean the sensor every once and a while with CRC Mass Air Cleaner. I have used it for years.
Pretty much everyone in the Hummer forums have had a problem with the oiled K&N filter and the MAF on stock motors...
I went with them GM aftermarket performance "non-oiled" CAI on the H2 and it works fine... I haven't yet looked into what the Vettes have for options, but both vehicle being in the same similar GM line, I personally would stay away from the oiled filters... |
I don't know about other brands, but if you pull a K&N out of its plastic wrap and install it, as is, that would be a mistake. It is, imo, far too heavily oiled. To do what peternj said above, I'd remove some of the oil before first installation with paper towels soaking it up. I'd also 'air-dry' it in direct sun, in a place where dirt won't get on it for a nice, long afternoon. Then, I'd install it.
this just reminded me that I ran out of electric cleaner!
btw one other little maintenance thing that can be taken care of at the same time is the door contact pads. A little cleaning really helps speed up their reaction time |
I use the best air filter element made. It's made by Donaldson, and uses nanofibers to filter out 99.97% of contaminants. It lasts for 50,000 miles and flows enough air to easily feed a 427 cu in engine running at 7,000 RPM. Oh, and it doesn't use any oil and will not release any oil that can coat the MAF and best of all, it comes as a standard equipment on all C6's. If that isn't good enough for you, then you can still make use of the Donaldson PowerCore technology and purchase the filter used in the ZR1, that filters just as well yet flows even more air and is a direct fit for the LS3/LS7. Just stop by your Chevrolet dealer and pick one up as it is standard equipment on all ZR1's.
AND...if you tend to pull a lot of high R's & G's, like during a DE Track day, you will pull oil into the Mass Air Sensor...Personal experience here. I added two catch cans, one on the PCV and the other on the valve cover vent. I was rather surprised at the amount of oil the cans would collect after one event.....and to think all of that was going through the intake :eek:
Check out attack blue filters from TKO Performance. Ask for Ed, they use a special oil that will not clog or damage MAF sensors. Just put one in the car last weekend and love it. It def. breathes a lot better. :cheers:
Originally Posted by JoesC5
(Post 1580101942)
I was warned by a dealership that alot of people who use these oilter filters end up messing up their MAF.:eek:
Originally Posted by LS WON
(Post 1580102583)
One of the problems, as I see it, is that people with the oil cotton gauze filters are in a dilemma. If they over oil the filter, they take a chance on screwing up sensors downstream, and if they under oil the filter, they take a chance of letting a bunch of dirt get through. |
I think i am going to get a catch can because to much oil is getting into my intake from the PCV. I wiped out a lot of oil out when i switched my throttle body out yesterday. I have worked on my own cars for 37 years since i have been driving and i have never seen oil in a new cars intake manifold.
(Post 1580103198)
Originally Posted by hisvett
(Post 1580101994)
Originally Posted by GOLD72
(Post 1580102340)
:iagree: You said it perfectly. That Donaldson comes in an AC Delco box. :yesnod:
I have a hardly used (less than 50 miles on it) K&N filter for sale for 2011 GS), $20, you pay for the shipping. |
Originally Posted by slamminc6
(Post 1580102289)
(Post 1580102636)
GM has experienced a lot of automatic transmissioned cars having all types of weird transmission shifting problems. GM will not work on any car, under warranty, that comes in with those symptoms, that have an oiled cotton gauze filter installed. They will not spend their dollars chasing problems caused by an aftermarket product. In fact there is a TSB that spells that out.
One of the problems, as I see it, is that people with the oil cotton gauze filters are in a dilemma. If they over oil the filter, they take a chance on screwing up sensors downstream, and if they under oil the filter, they take a chance of letting a bunch of dirt get through. The Corvette I keep it factory stock and am using the original factory air filters. |
Originally Posted by marc8090
(Post 1580105991)
And you know it breathes better how?
If they have in fact measured the airflow of both filters using strict industry accepted protocols, then why don't they post the tests they performed, instead of just telling us they flow 45% more air? Same goes with filtration tests and laminar air flow tests. |
