What brake pads do you use with Hooiser R6?
DTC 60 all four corners?
DTC 60 front and what in the rear? DTC 70 front and DTC 60 rear? Whats your experience.. Tom |
Ran DTC 70's in front and 60's in rear for quite a while with no problems.
Now running 70's all around. Can tell a diffrence in trailbraking into a corner. Rear of the car is more prone to trying to pass the front but managable. Still running this setup. DTC 70's are prone to running very hot. Cool air is your friend. If you go the 70's route you will need at a minimum a front spindle duct kit. We went further and routed the duct work to the front grille area of the car and havent had any fade yet. It was still an issue with just the spidle ducts. But no where near as bad as just running what came on the car. And pad life increased 10 fold |
Originally Posted by Screamin Z
(Post 1580202199)
Now running 70's all around. Can tell a diffrence in trailbraking into a corner. Rear of the car is more prone to trying to pass the front but managable. Still running this setup. DTC 70's are prone to running very hot. Cool air is your friend. If you go the 70's route you will need at a minimum a front spindle duct kit. We went further and routed the duct work to the front grille area of the car and havent had any fade yet. It was still an issue with just the spidle ducts. But no where near as bad as just running what came on the car. And pad life increased 10 fold I was wondering if I use DTC 60 in the front what should I use in rear...same or HP PLus? or would I be better off DTC all around like you did in the past. Tom |
If you go 60's in the front id just stick with 60's in the rear. Interchangable pads from front to rear are a plus aswell.
70's front, 60's rear. The initial bite is a bit aggresive and you will probably see greater rotor wear. I switched to Cobalts.
70s up front and 60s in back for me. No issues but brake ducting is advisable as screamin z said. :thumbs:
Front:
Carbotech™ XP20™ The latest iteration of the highly successful XP™ series of compounds. XP20™ is a step up from the highly successful XP16™ compound. With an extremely aggressive initial bite, the most linear torque curve to date and excellent fade resistance the XP20™ leads the highly successful XP™ series line of compounds from Carbotech™. XP20™ has a temperature range of 275°F to 2000°F+ (135°C to 1093°C+). Carbotech™ XP20™ maintains our tradition of having the outstanding release and modulation that has made all other Carbotech™ compounds so successful. The XP20™ as with other Carbotech™ compounds is very rotor friendly. Carbotech™ XP20™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise. Rear: Carbotech™ XP10™ When Carbotech™ unleashed the XP10™ to the general public it was an instant success. XP10™ immediately gathered multiple regional, divisional, and national championships. The XP10™ has a very strong initial bite friction material with a coefficient of friction and rotor friendliness unmatched in the industry. Fade resistance is in excess of 1650°F (898°C). Due to the high level of friction and bite, this material is recommended for cars weighing around 2,900lbs or less. XP10™ still maintains the highly praised release, excellent modulation and rotor friendliness that have made all Carbotech™ compounds so successful. Carbotech™ XP10™ is not recommended as a daily-driven street pad due to possible elevated levels of dust and noise. |
I run Hoosiers R6's but by no means do I race head to head at high speeds. The tracks I run I might get to 140mph.... I ran last year with DTC 60 front and HP Plus rears. I never felt any brake fade with these compounds. What to you recommend for me...XP20 or something less abrasive... Are Xp20's easily controlled or are then abrupt in thier bite..?
Tom |
Another vote for CarboTechs
XP10 fronts and XP8s rear, try them and you will never go back. |
Do you recommend single piece pads? Why would you go with multiple piece pads?
DT70s front and back. Works well!
Originally Posted by trapp
(Post 1580211888)
Give me a call I will be happy to help you out. |
(Post 1580211888)
Bill |
