Questions on which X pipe........
First of all, I fully understand their are really no perfomance gains to be had by installing an X pipe. My reasons are for sound quality only. I'm not a big fan of the motorboat sound at idle or the light popping sounds during deceleration....... I have been told that an X pipe will balance my exhaust note.
I currently have stock headers, cats, H pipe and Borla Quad tip Cat back exhaust. I am looking at the Borla X-pipe, and Cora which look basically the same to me. Do they function as well as the so called "True" X-pipes made by Bassani and Magnaflow? If you run an X pipe, or have opinions about the different X pipe's available, chime in with your opinion. I am leaning toward the Borla X-pipe since I'm already running the Borla cat back but I thought I should find out about the others first before I make a decision. Let me know your thoughts :cheers: |
I always run the x-pipe that was manufactured to go with my catback.
Originally Posted by RaW Z06
(Post 1580205538)
I have a full Corsa set including X pipe and still get the pop when off throttle. I don't mind it at all but some people do. I hear it will/would be a lot worse without the X pipe.
Originally Posted by Buggyman
(Post 1580205940)
I have the X pipe with my quad powers and I still get the pop.
But I wouldn't have an exhaust on a performance car that didn't pop. I still recall muscle cars from the sixties that popped when you changed gears and let off the throttle, I love it. But in order to get rid of the pop, you're going to have to go to a tame exhaust. Those Borla's are going to pop. They're designed that way as are most of the more aggressive mufflers. |
My Corsa with x-pipe still pops. Best exhaust system I've ever purchased. Looks and sounds great!
I bought the Borla for my GHL's and it sounds great! Can't compare to Corsas X never had one. I went from stock to the Borla x and GHL's leaps and bounds over stock. I will say that the deciding factor for me was cost and if I remember correctly I could have bought 2 Borlas for one Corsa and the fact that there is no real gain other than sound I figured why spend the extra cash!
My '01 ZO6 runs Borla Stinger exhaust with a Magnaflow cross-over. I like the sound and the full cross-over fit just fine.
http://i296.photobucket.com/albums/m...3720090926.jpg |
Don't get me wrong, I like the aggressive sound of my Borla's. :rock:
I don't have to purchase an X-pipe to be happy with my exhaust. I guess I'm just trying to figure out if the change in exhaust note / quality is worth the $300 for an X pipe install. |
Some more comments based on a thread I started earlier. I'm considering adding a Corsa X-pipe to match my Corsa Indy Pro exhaust when I drop my exhaust to install a thermal tunnel plate later this spring.
http://forums.corvetteforum.com/c5-g...-worth-it.html |
Originally Posted by jrose7004
(Post 1580205702)
Or the LT headers you install. No matter, you will still have some decel pops if you decel at higher RPMS!:thumbs: |
(Post 1580205702)
Ok, so anyone out there running a Borla X-pipe with their Borla Quad tip Cat Back? |
