:cheers:
:cheers:
Just ordered mine. If I put aluminum foil underneath of this insulator, would it help more to reduce the heat? Probably not....
Originally Posted by Aviator_JPN
(Post 1598376798)
:cheers:
Originally Posted by ljorges
(Post 1580776367)
So it wouldn't matter if the interior is shale? You don't see this once it is in place?
Thanks, Les |
:cheers:
:cheers:
It works great...should have ordered it long ago!
Originally Posted by doublenut9
(Post 1599758500)
** This Product fits all C5 Models 1997 thru 2004 **
Are you searching for a low cost and easy method to reduce the temperature inside your center console? Reduce your interior console temperature to a more manageable level by using our easy to install C5 Center Console Insulator. Installation is just a matter of pressing the Console Insulator into place. Laser cut for a perfect fit. 1/4 inch insulation covered in black felt to match the stock interior console. Experience a noticeable reduction in interior console temperature with an easy to install and inexpensive alternative. http://i113.photobucket.com/albums/n...Picture005.jpg http://i113.photobucket.com/albums/n...Picture006.jpg Order on our website at http://www.topflightrepro.com/corvet...products.shtml |
:cheers:
Ordered 10/18 How log before shipped?
Originally Posted by Clancy209
(Post 1600350759)
Best Regards Peter C |
(Post 1600350759)
Still waiting patiently |
(Post 1600376871)
Best Regards Peter C. |
Installation is just a matter of pressing the Console Insulator into place. Laser cut for a perfect fit. 1/4 inch insulation covered in black felt to match the stock interior console. Experience a noticeable reduction in interior console temperature with an easy to install and inexpensive alternative. http://i113.photobucket.com/albums/n...Picture005.jpg http://i113.photobucket.com/albums/n...Picture006.jpg |
clicked on you web site and all it showed was for c6 { 2000-2015 ] I had said in my post my corvette was a c5 1997
Originally Posted by 97Chuck69
(Post 1600456453)
