Another problem....
As you all know I've been working out the bugs in my 82 and now have fallen onto another problem. I've been seeing a drop or two of coolant on the garage floor and even seen a tiny puddle in the right front block concave area right below the CTS. I cleaned everything very good to see where the leak is coming from. I started the car and when she warmed up the coolant was seeping through the intake passage about a 1/2" from the CTS. I don't see a crack but there has to be one. So my question is can I mix up some JB Weld and wipe over that area?? I don't know how else you would fix that??:ack:
if its a crack that opens with heat and closes when cool, j.b may not work, could you possibly take a pic of the area, it may not be a crack at all and another member may have had it happen to them. and have a solution
Originally Posted by oldalaskaman
(Post 1580326314)
the bottom link under the pic, you click on that and then paste it to your thread, not concerned with seeing the crack, interested in seeing the exact location, you may have something someone else has seen in that exact location. that may be easily fixable. mybey not, but its worth a try
Originally Posted by alconk
(Post 1580326493)
I'd be more than happy to post a picture but not for sure how to do it?? I do have a Photobucket account though.
http://forums.corvetteforum.com/help...es-thread.html Good luck- |
(Post 1580327809)
(Post 1580329225)
http://i929.photobucket.com/albums/a...k/DSCN0559.jpg Hopefully this works
it looks like your sender was screwed in to tight, or that bolt was tightened out of sequence, the right option is to pull your manifold and get it welded or replace it, if thats the oe manifold a steel one from the same era would eliminate future issues, welding would run bout $30
Check the torque on that shiny new intake manifold bolt.
:thumbs: |
(Post 1580329471)
Check the torque on that shiny new instake manifold bolt.
:thumbs: |
(Post 1580329340)
place a can of 'block sealer' in the radiator and drive it.....by Solder Seal. Liquid Wrench, Gunk are a few other products made by them...It really works should be available at most parts houses in the chemical lane
:iagree: I just hesitate to suggest these in case they dont work, but 9 time out of ten they do.
they can also clog water ports and make for more damage to components then they save. you can get the manifold fixed if it is steel like previously sugested for around 30 dollars. that is your best bet other wise try the jb weld i have seen what the fix aleak xrap does to the inside of an engine,radiator, water pump it is not pretty
If you don't want to remove it use Blue Devil and it won't clog anything.
Other wise it can be tigged or just replaced. |
