2006 base c6 A6 brake pedal height
2006 base c6 a6 auto brake pedal too high
got a kirkey seat in my track car and want to lower the brake pedal height to the same level as the gas pedal cause i brake with my left foot and my left knee is higher than my right knee anyone try this before? any tips? |
I haven't seen anyone lower the pedal height on the brakes, but most will raise the throttle to meet it under heel/toe conditions. I do not believe there is an adjustment on the master cylinder rod, but again I haven't checked that on the OEM setup.
I'd have to agree with anthony. I actually raised the pedal on my c5. I have yet to drive a production car that had the brake pedal too high. Keep in mind that under severe braking the brake pedal will most likely be lower or level, at best, with the throttle. That is not desirable on the track.
Originally Posted by trackboss
(Post 1580418112)
The way I have seen it done is either with a composite or aluminum bolted to the gas pedal. Typically making it wider and taller. Shouldn't have to move it much. Event with stainless lines, and a hard pad on the car the brake is still going to fall at least an inch.
Originally Posted by ritch ford
(Post 1580420247)
Might I ask how you raised the pedal?
thinking of making a shorter pushrod(the rod that pivot on the pedal and enters the brake booster) to lower the pedal
