Thanks to all for the info. I pulled my blower motor out a few days ago and I'm still trying to get it cleaned up and get rid of the smell.
How is the fan/blower motor removed? I don't have mice problems, my fan is just loud. Especially on high. On low it's no big deal. Have always thought maybe there is something in there or there is a problem with the fan.
You guys are too much - were xrays taken of the deceased mouse to determine the angular acceleration which caused blunt force trauma?
Another trick I recall from college days (don't ask!) are those little "cakes" they throw in the bottom of the urinals - like Dan Akroyd about the marine glue - "strong stuff"! |
Originally Posted by IRON MAIDEN
(Post 1590027408)
It looks like this and you have to do the LIMBO to get under the dash to access the screws. If your good with a Mirror and flash light, it may save your back.
It goes here with three screws. You can also see the motor controller mounted on te bottom of the box: http://img.photobucket.com/albums/v4...7/DSCF0045.jpg http://img.photobucket.com/albums/v4...7/DSCF0006.jpg http://img.photobucket.com/albums/v4...7/DSCF0006.jpg DAMN MICE! :smash: http://img.photobucket.com/albums/v4...7/DSCF0116.jpg No X Rays but,, the front feet extruded from the rotor tells the story. It was NOT happy!!! WEEEEEEEEEE! The carnival ride from HELL! http://img.photobucket.com/albums/v4...7/DSCF0148.jpg |
So not too bad. Pull the passenger seat and lay down!!! The fan sounds like it's out of balance. So it gets louder the higher the setting.
(Post 1590052262)
Originally Posted by Bill Curlee
(Post 1580510608)
:lol::lol: Did it look like this????????????????:rofl:
http://img.photobucket.com/albums/v4...7/DSCF0116.jpg http://img.photobucket.com/albums/v4...7/DSCF0149.jpg See,, the difference between you and me is,, I got the bastard! He didn't too much like the fan on full speed!!! LMAO His little legs stuck out and got hammered!! http://img.photobucket.com/albums/v4...7/DSCF0148.jpg This is what came out of the air box after the fan was fully removed and I reached in and pulled it out! You can see the hose that I adapted to my wet and dry VAC: http://img.photobucket.com/albums/v4...7/DSCF0140.jpg CALL ME (PM SENT) Had this problem and over came the smell... You most likely only solved HALF the issue. The OTHER HALF of the nest is most likely still inside the air box.. Remove the fan AGAIN. Reach up inside the the air box. When you reach in, you will dead end into the evaporator.. Run your hand straight down and feel for TRASH, TURDS, Nuts, and once ALL the trash is out, use a wet and dry VAC with a piece of rubber 1" hose adapted to fit on to the VAC hose. Go in and suck out all the remaining stuff. When you THINK THAT YOUR DONE,, look in with a light and mirror and make sure. Protect the seats and carpet and dump in some diluted bleach and water. (it does NOT take much bleach) See if the water runs out of the AIR BOX DRAIN on the passenger side of the fire wall in the engine compartment. If it doesn't run out,, you have trash and turds in the drain and you will need to get that unplugged! Once everything is 100% clean, inside remove the wiper cowl cover and make sure all that is clean! Under the COWL was more crap! http://img.photobucket.com/albums/v4...ment022_sm.jpg http://img.photobucket.com/albums/v4...7/DSCF0127.jpg Make sure that you clean out all the cowl water drains!!! They can stink too if that have trash in them also! http://img.photobucket.com/albums/v4...27/achose3.jpg http://img.photobucket.com/albums/v4...wldrainsII.jpg MOUSE DEFENSE!!! http://img.photobucket.com/albums/v4...DSCF0072-1.jpg RICBEAR "Go get Ozium. Turn on the blower on lo. Locate the intake vent outside. Unload the can or cans. Ozium is a bacterial eliminator. Before putting the blower back in take some stiff wire and carefully fish in the ducts for the body. Had to do that with the truck for one.. " Yep, Great stuff and it smells GOOD! PM SENT BC |
I found two possible entry points,the cowl drains and the opening at the pass wiper spindle. Anyone know of any other possible openings?
Originally Posted by old stingray
(Post 1590076220)
The LEFT and RIGHT sides where the cowl cover closes off the well, theres an unsealed area. http://img.photobucket.com/albums/v4...ment022_sm.jpg All of the cowl drains have NIPPLES on them that are closed together when they are not draining: http://img.photobucket.com/albums/v4...27/achose2.jpg http://img.photobucket.com/albums/v4...ephotos005.jpg http://img.photobucket.com/albums/v4...ephotos004.jpg HVAC AIR BOX drain nipple: http://img.photobucket.com/albums/v4...uumline006.jpg Mouse eye view of the NESTING AREA! http://img.photobucket.com/albums/v4...ephotos034.jpg |
Bill,thanks for the the info and fast response,you're the man.:thumbs:
Good grief what a mess. I feel for you and if it makes you feel any better your pain has perhaps helped us all. :thumbs:
Glad you found a solution. |
clockman
Originally Posted by SCOTTVETTE1989
(Post 1580496868)
A mouse in my heater box!!!
I just pulled my 01 Z06 out of the garage after a long winter. It stinks!! I pulled out the blower motor and there was a nest. I cleaned the blower motor area but it still smells bad. I tried spraying deodorizer,no help. Can anyone give me instructions on how to pull the heater box out from the dash. Thanks Scott Jim C |
clockman
(Post 1580499295)
Luckly the interior doesn't smell. UNTILL you turn on the heat! thats why I want to pull it apart. I just haven't had a dash out of a c5 yet. Just looking for some tips.
jim |
clockman
(Post 1580512476)
Thanks guys for all the help. I have had the blower out and cleaned everyware i could reach,standing on my head. Removed the cowl screen and nothing was found,still stinks. I will be disassembling more this weekend.:ack:
All is good now |
clockman
(Post 1590076872)
The COWL WELL has numerous mouse entry points. The only way INSIDE the car is the opening where the HVAC Air box gets its outside air.
The LEFT and RIGHT sides where the cowl cover closes off the well, theres an unsealed area. http://img.photobucket.com/albums/v4...ment022_sm.jpg All of the cowl drains have NIPPLES on them that are closed together when they are not draining: http://img.photobucket.com/albums/v4...27/achose2.jpg http://img.photobucket.com/albums/v4...ephotos005.jpg http://img.photobucket.com/albums/v4...ephotos004.jpg HVAC AIR BOX drain nipple: http://img.photobucket.com/albums/v4...uumline006.jpg Mouse eye view of the NESTING AREA! http://img.photobucket.com/albums/v4...ephotos034.jpg jim |
clockman
(Post 1590076872)
clockman
(Post 1590024704)
jim |
I got everything cleaned up and added a few drops of peppermint oil in the duct work,fan and heater box, it is supposed to be a mouse deterrent plus it makes the car smell great. All is good for now. :thumbs:
clockman
(Post 1590294647)
