-   C6 Tech/Performance (https://www.corvetteforum.com/forums/c6-tech-performance-101/)
-   -   Do all C6's have the TR6060? (https://www.corvetteforum.com/forums/c6-tech-performance/3066431-do-all-c6s-have-the-tr6060.html)
98Redbird 05-29-2012 03:43 PM
Or just the Z06's? Also, I heard the gear ratio's are exactly the same between the T56 and the TR6060. I have a C5Z right now with the MN12, how would the gear ratio's in a base 2012 differ from the MN12?
Turbo6TA 05-29-2012 03:49 PM
Don't know anything about the C5s, but here are all the transmission and final drive ratios for the C6 cars:
http://i127.photobucket.com/albums/p...GearRatios.jpg
Joe_G 05-29-2012 04:21 PM
08+ has the 6060. 07 down has the same T56 as in the c5.
C6 Z51 manual cars have the same tranny as the c5z06 except the c6 has a cooler integrated.
The base model c6 is the same as c5 except for 08+ which is the 6060.
TNTC4VETTE 05-29-2012 04:22 PM
6060 in all from 08-up.
Quickdraw Joe beat me.
JCtx 05-29-2012 04:49 PM
Correct. But with some improvements in 2011 :D.
MikeyTX 05-29-2012 07:46 PM
Which were ? :toetap::D
erick_e 05-29-2012 07:59 PM
Except for the rated torque capacity
Overview
Both the standard Corvette and the high-performance Z06 use the TR6060 designated as MM6, which is validated to 500 lb-ft of torque, while the TR6060 with the Z51 option features higher ratios and is designated as MZ6. It is validated to 430 lb-ft of torque. The ultra high performance ZR1 uses the TR6060 designated as the MH3, which is validated to 650 lb-ft of torque. The CTSv uses the MG9 version of the TR6060 validated to 560 lb-ft of torque. The Camaro uses the M10 gear set validated to 430 lb-ft of torque.
Improvments were made in 2010
2010 Tremec TR6060 (MM6/MZ6/MH3/MG9/M10) car transmission
2010 Model Year Summary
Tremec TR6060 six-speed manual car transmission
New Features and Benefits for 2010 model year
• Second gear synchronizers using carbon material
• Second gear synchronizer design with advanced and asymmetric teeth (CTSv in 2009)
• Improved transmission pump pick-up
• Implementation into the V-8 Camaro
MikeyTX 05-29-2012 08:04 PM
Ahhh shucks .................... I was hoping for free beer and pizza :rofl: Thank you btw !
JCtx 05-29-2012 11:27 PM
Didn't know about those other improvements :blueangel:. I was talking about the triple cones in gears 1 thru 4, supposedly implemented in 2011. Any truth to that?
MikeyTX 05-29-2012 11:37 PM
Bet Talon90 can answer that question.
JoesC5 05-30-2012 11:19 AM
Because the 6060 has 20% wider gears then the T56, the triple cone synchros were part of the 6060 redesign from the start(2008).
1stGlance 05-30-2012 12:20 PM
Did you already see his ?
You may have aleady sen this - it does have some good information in the thread...:thumbs:
http://forums.corvetteforum.com/c5-f...ous-power.html
JCtx 05-30-2012 03:52 PM
Thanks man. Apparently the triple cones are only on gears 1 and 2, not the first 4. Now we know. Seems like a very robust transmission for GS stock power :thumbs:.
Joe_G 05-30-2012 04:03 PM
Yes indeed...I covet that 6060 trans after breaking my third gear blocker ring twice while drag racing!
MikeyTX 05-30-2012 09:29 PM
At least now I know and understand to a degree why the M6 on the '11 feels o much better than the one on the '07. I knew the transmission had changed for the better, I simply didn't know all that had been done. Since I don't track the car I'm wondering if I even ought to change to an MGW as I did on the '07. It made a heck of a difference on the T-56
JCtx 05-30-2012 09:42 PM
Originally Posted by MikeyTX (Post 1580948231)
Since I don't track the car I'm wondering if I even ought o change to an MGW as I did on the '07. It made a heck of a difference on the T-56
I'm not going to man. I'm very happy with this tranny; it has the perfect throws and side gate spacing for my tastes. And shifts great too, with positive engagement and robust feel. Keeps getting better and better after 900 miles. And when I replace the fluid with synthetic at the 3K-mile mark, I'm sure the little notchiness left on the 3-2 downshift will be gone. It's a pleasure to drive and shift this car. I don't understand how others can miss this experience with an auto tranny, even if it's slower than an auto. One of the few pleasures in life I can still enjoy at will :thumbs:.
MikeyTX 05-30-2012 11:22 PM
Yup, I'm right there with ya. I'm just going to buy the new SS sedan for a trip car as it will be easier for the s/o with her back issues to travel in than the Vette. That way I can keep the M6 for me. :D
hitdank 05-31-2012 06:55 AM
why does the instruction manual show a 1 quart difference between the z06 and the base?
Joe_G 05-31-2012 07:03 AM
Z06's, grand sports and z51's have coolers.
And they are necessary and effective on the road course. I run trans and diff temp gauges, the trans never gets above 200, the factory oil cooler works well too but my diff will get up to 280+ after 20-30 minutes which is when I get off track.
The z06's have a diff cooler too for this reason. Wish I had one.
I've seen c5z friends cook manual trannies on the track. 3 of them matter of fact. The trans high temp light never came on (which if I recall correctly comes on at 270 degrees).
If you are going to track your car a trans and diff temp gauge is a good item to have.
glass slipper 05-31-2012 06:17 PM
There are two different transmissions used on the ZR1, the MH3 and the ME2. Your chart lists the MH3 ratios, the ME2 has ratios of 2.26, 1.58, 1.19, 1, 0.71, and 0.50. :cheers:
