Get my L48 to 350 horsepower.
I would like to get 300 to 350 horsepower from the L48 in my car. I don't want to go with a crate engine because of my budget. I have about $2500 to spend. I recently sold a 99 and would like to get about the same hp as that did. I have a basic idea on what I want to do. I just want to see what others would do.
How deep are you willing to go into the engine? A head, cam and intake swap will do wonders for it. The Edelbrock package 2022 would fit the bill but I would change the cam, the ones in their packages are really old technology but should be easy on the valve train.
My L48 is now a 350 hp 390 Tq motor done by my local engine builder. Its his own version of a GM crate motor. 2 bolt main 9.0-1 compression, Dual pattern comp hydraulic cam non roller. Heads are warmed over 882 truck heads, 1.94 intake 1.60 exhaust. intake is an Eddy dual plane with a 1406 eddy carb.
I dropped off a block crank rods oil pan intake carb and Distributor. He supplied the rest. Put the motor on the dyno, broke in the cam, seated the rings and made some pulls. $3600.00 out the door tax paid. Comes with 6 months/ 6000 mile warranty |
Headers and exhaust.
Cam, heads and intake. Vortecs are well within your budget. Tune. Should get you right there :thumbs: |
I was thinking about the Performer package from Edelbrock.
The following link is to a thread I posted with some rear wheel chassis dyno data from my build up. The cam gave the largest power increase but I doubt the results would have been the same if the other modifications were not in place.
http://forums.corvetteforum.com/c3-t...mp-xe268h.html It is important to note that since I finished the motor, I had to upgrade the torque converter to a 2800 stall and switched the rear end to a 3.55 unit in order to make the car operate in the cams power band. Chevy High Performance did a series years ago about the Vortec heads and matched it with a comp cam xe268h cam. It's going to take both components and new heads can get pricy quick. You may find something interesting on craigslist... |
Originally Posted by 540 vette
(Post 1580941136)
use your old engine as a core and build it to a L-79`s specifications and you engine is still all stock appearing with its correct numbers...the result, 350hp
I have a very tired L48 motor also. I have chosen to go the crate route.
Take the time to look at www.phoenixengine.com they can give you the motor you would like for your budget. Also, take a look at Jeggs or Ecklers they offer Chevy crates 290 hp for just under $2K. Good luck. Let us know what you decide to do. P.S. If I have unintentionally committed a forum faux pas by suggesting a vendor that is not listed on the forum, then I apologize. Good day. |
Jegs has a couple of crate engines with what you're looking for in your price range and are offering free shipping.
I myself would build the engine into a 383. I loved the feel in my 77 many years ago. |
AFR 180 heads about 1500-
Cam in the 220ish range @.050 FT or hyd roller take your pic. Big price difference. Even throwing an Isky 270 mega cam at it would work. Good used dual plane intake 650+-carb 1-5/8 primary headers Recurve your distributor roller rockers possibly pushrods Gaskets fluids Should creep up on 350 at the tire Id bet and be close to budget. Perhaps a touch over but youll love how it runs. |
The L48 is very similar to the GM crate 350".
You really should review the series of acticles by Chevy Hi-Performance on a GM crate 350". This should give a good idea of it takes to get a low compression 350 to over 400hp.:yesnod: Take a look: http://www.chevyhiperformance.com/te...ild/index.html
http://www.chevyhiperformance.com/te..._ii/index.html http://www.chevyhiperformance.com/te...iii/index.html http://www.chevyhiperformance.com/te..._iv/index.html Hope this helps ya, cardo0:D |
Originally Posted by Jedi926
(Post 1580942628)
Take the time to look at www.phoenixengine.com they can give you the motor you would like for your budget. Also, take a look at Jeggs or Ecklers they offer Chevy crates 290 hp for just under $2K. Good luck. Let us know what you decide to do. P.S. If I have unintentionally committed a forum faux pas by suggesting a vendor that is not listed on the forum, then I apologize. Good day. http://www.ripoffreport.com/director...ix-Engine.aspx |
I really don't want to pull the motor from the car. I will tear it down to the short block and add heads, cam, intake and carb. And headers. I am going to order a set of Hookers probably tomorrow.
Do your self a favor, don't skimp on the heads, there are many good heads out there & there are tons of cheap heads, nothing out there in the line of good cheap heads. I favor afr, great flow with hogging out the ports. they really can't be beat in the 23 degree head category.
Originally Posted by 63mako
(Post 1580948174)
I would do some research before dealing with phoenix engines.
http://www.ripoffreport.com/director...ix-Engine.aspx Thanks 63Mako, just read the reports, that will make me think twice about using this shop. Everything I read was positive. Great tip. |
(Post 1580949083)
(Post 1580943766)
(Post 1580949270)
:thumbs:Great advice! Look at the Howards cams at Summit. $500 gets you a billet core retro hydraulic roller and lifters. AFR heads need the +.500 lift of a roller cam to get the full benefit of the heads.
(Post 1580949240)
No problem. I remembered a forum member a few years back that had major problems with no resolution so I did a quick search.
