WTB: 1990 Automatic Neutral Safety Switch Pigtail
Hey folks,
I need the pigtail (wiring harness connector) that the Neutral Safety Switch plugs into. I can get a partial dash harness for about $75.00, but all I need is that one plastic piece. My Neutral safety switch somehow got hot enough to melt, and it melted the plastic connector with it. Now it doesn't make a solid connection so the car only starts when it wants to. |
I might have one. i swapped my auto to a 6 speed, so if i can find it, it's yours.:thumbs:
Originally Posted by cadmaniac
(Post 1581131288)
I've done a little homework. From what I understand the harness in any Automatic Corvette from 84 through 96 should use the same Neutral Safety switch, which means the connector will be the same as well. The same connector was also used in the Typhoon and Sonoma. I've been meaning to take a photo of the pigtail, but it's been chaos at home for the last week. I'm not having any luck with the junkyards other than being offered a complete harness. I'm almost at the point of just soldering wires directly to the switch and tossing the pigtail. |
