can you emulate an LS engine using a Gen I block....
i realize the LS parts won't fit a Gen I, but can similar heads/pistons/intakes/electronics be used to get the wizzbang of an LS engine?
Bill |
A good fabricator can make or fit almost anything. The questions should be, why would you want to and is it cost effective?
:eek: |
1 Attachment(s)
Originally Posted by MiguelsC2
(Post 1581127159)
:eek: there may be a lot more improvements that are possible for a Gen I engine if one thinks outside the box. Bill |
Originally Posted by wmf62
(Post 1581127308)
the real question is 'why not'.... in my simple mind it's a heck of a lot more cost effective and easier than the conversions required to fit an LS in a C1,2,3 or 4.
there may be a lot more improvements that are possible for a Gen I engine if one thinks outside the box. Bill Why mess with success? :D Buy a street rod to play with. :) Chuck |
Bill,
Motown makes a block that accepts LS heads and intakes. Here's an old article on it: http://www.hotrod.com/techarticles/e...e/viewall.html DT |
Originally Posted by Chuck Gongloff
(Post 1581127329)
Your car looks great "as is". It also performs great "as is".
Why mess with success? :D Buy a street rod to play with. :) Chuck i had lunch at Taco Bell, i guess that's what caused me to 'think outside the box"... :thumbs: Bill |
Originally Posted by NOM61
(Post 1581127410)
Bill,
(Post 1581127722)
Chuck
i had lunch at Taco Bell, i guess that's what caused me to 'think outside the box"... :thumbs: Bill AND, they also say that "busy hands are happy hands". :D Knowing you, it looks like a new power plant is in your future. Gotta keep those hands busy. :thumbs: Chuck |
(Post 1581127329)
Why mess with success? :D Chuck :cheers: Paul |
1 Attachment(s)
Originally Posted by Fawndeuce
(Post 1581128520)
You know Bill way better than I do Chuck, so ya 'gotta you know that his need to continuously mess with it is just more powerful than he is. :lol:
:cheers: Paul |
(Post 1581128520)
:cheers: Paul Bill, you need to buy ANOTHER project. :D Can't keep messin' with the same one. "Put a fork in it. It's done". :D And, since I'm quoting a lot of old adages in this thread.............. "If it ain't broke, don't fix it". :D Chuck |
i think i'll go to Saskatoon instead....
:auto: Bill |
(Post 1581129078)
:auto: Bill http://www.youtube.com/watch?v=ZvbqGubZmgo |
1 Attachment(s)
:woohoo:
You can get can get computer controlled EFI and after market heads for a Gen 1 small block and get similar performance to an LS motor. The down side is the parts are kind of pricey. The upside is there will be fewer electronic and computer glitches than an LS installation.
Popular Hot Rodding has a good series of articles on Building The Anti-LS Motor. They build a Gen 1 SBC and with high quality after market products and get performance numbers better than an LS crate motor. LS conversions are heavily documented during the installation. Problems after the installation are not documented as well. Engine management problems can be difficult to identify and expensive to fix. Im not knocking LS motors and my next build will use one. Im just saying they can have their own set of problems. |
Originally Posted by uxojerry
(Post 1581130990)
Popular Hot Rodding has a good series of articles on Building The Anti-LS Motor. They build a Gen 1 SBC and with high quality after market products and get performance numbers better than an LS crate motor. LS conversions are heavily documented during the installation. Problems after the installation are not documented as well. Engine management problems can be difficult to identify and expensive to fix. Im not knocking LS motors and my next build will use one. Im just saying they can have their own set of problems. :thumbs: Bill |
(Post 1581132353)
thank you.. that answers the performance side of the equation, how about economy/efficiency?
:thumbs: Bill |
The LS motor has a wider V angle allowing for larger heads and better airflow. Besides a performance advantage from bigger heads, the rest is simply computer controlled timing and fuel injection. An SBC with computer controlled EFI can get equivalent fuel economy to an LS motor.
(Post 1581134112)
