Cleaning up the shelf
Finally got around to clean up the shelf. :woohoo:I found a few parts I no longer need. Thought I put them up for sale here:
1. Spindle bearing housing left and right, will fit 63-82 but came off of a 77; $45 each 2. Used idler arm assembly, fits 63-67; $40 3. Two half shafts off of a 78 for $50 each 4. After market brake booster for 65-67, $60 5. Original exhaust manifold right and left, L18, for small block chevy $60 6. Replacement fan clutch small block chevy for $30 7. Original 67 gas pedal (I throw that in for free with a purchase of any of the other parts). Is worn out 8. Drive shaft off of a 67, D217 spicer. It has a groove in the middle where something rubbed on. Still in good shape though. $60 9. Replacement rear view mirror 67 for $20 10. Voltage regulator 1119515 Delco Remy, April 64 Corvette; $85 11. Dipstick replacement 66 small block, all except 350 hp; $8? or free with purchase of another item if you like 12. 78 rear swaybar assembly; $88 13. 78 rear crossmember; $80 14. Master cylinder cover; $8 15. Oil fill tube cape, 67 Corvette; $8 16. Hinge and radiator reinforcement; $15 for pair 17. Replacement jack handle for 67: $15 18. Replacement tie rod ends for 53-62 and other GM cars; $50 for all four 19. Replacement GM outer tie rod ends; $45 (pair) 20. Red intake manifold for 250 hp; 3844457; dated L73; $120 Pick up here in Tucson would be great but I would ship, too. I tried to make the prices as reasonable as possible. Make sure to keep in mind that the shipping cost would be added to the price. :ack:I am happy to send pictures on request and figure out shipping cost upfront if you like. :yesnod: ...ya, I really like those smilies :cool: |
