Ragin Racin's twin intake pump (2003.5 and newer)
Ragin Racin has developed a new solution to your fuel problems. Our twin in-tank system alows you to maintain stock drivability and noise levels until your higher fuels demands are needed. Our all aluminum billet fuel pump bracket houses 2 Walbro 255l/hr fuel pumps for fuel needs up to 1000hp or you can upgrade to 2 Aeromotive Stealth pumps if more fuel is required.
Our supplied custom wire harness allows you to run both pumps simultaneously or have the second pump activated by a boost reference switch. Fetures Include:
http://forums.corvetteforum.com/imag.../wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 1023x685 and weights 48KB.http://i610.photobucket.com/albums/t...n/DSC_0224.jpg http://forums.corvetteforum.com/imag.../wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 1023x685 and weights 49KB.http://i610.photobucket.com/albums/t...n/DSC_0222.jpg http://forums.corvetteforum.com/imag.../wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 1023x685 and weights 75KB.http://i610.photobucket.com/albums/t...n/DSC_0220.jpg http://forums.corvetteforum.com/imag.../wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 1023x685 and weights 67KB.http://i610.photobucket.com/albums/t...n/DSC_0219.jpg http://forums.corvetteforum.com/imag.../wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 1023x685 and weights 92KB.http://i610.photobucket.com/albums/t...n/DSC_0214.jpg __________________ http://i29.photobucket.com/albums/c2...vectorized.png Randy Leger 337-278-8397 sales@raginracin.com http://www.raginracin.com |
Thanks for the sales!
:cheers:
Thanks for the sales!!
Appreciate the sales!!
Any drawback to running both pumps continuously besides slightly higher noise ?
Also....I'm wanting a complete fuel system (sans injectors) that's E85 compatible....think you can fix me up ? |
Originally Posted by Six-Gun-Todd
(Post 1581391126)
Also....I'm wanting a complete fuel system (sans injectors) that's E85 compatible....think you can fix me up ? It will heat the fuel up more and draw more current with both pumps running. I do have injectors. |
:thumbs:
what will this setup support with the Stealth pumps?? also what would you recommend for E85??
Thanks |
Originally Posted by walhan_qtr
(Post 1581447570)
Thanks |
Fuel pumps are in stock!!!
ttt
I have both aero 340's and the 255's built and ready to ship.
Thanks for the sales!!!
We will be closed this weekend to move into our new facilaty. We will be open Monday at 9 am at 209 Harold Gauthe Dr in Scott LA.
In stock and ready to ship!
Thanks for all the purchaces!!!
