A PPG question
I am going to repaint the bumpers on my 81 with PPG paint, here is what I have:
PPG base coat (JB base coat) mix 1 part to 1 part JR 506 Med. Reducer? JC 630 Clearcoat and JH6370 Hardner, what is the mixture on this? As I understand it I should apply the base coat, allow a minumim of 30 minutes then apply 2 to3 full wet coats of clear. How long between clear coats? Correct???????????? (and yes I have been reading threads on painting and cannot clearly answer these questions) Thank you in advance Don |
Originally Posted by donjack
(Post 1581306151)
PPG base coat (JB base coat) mix 1 part to 1 part JR 506 Med. Reducer? JC 630 Clearcoat and JH6370 Hardner, what is the mixture on this? As I understand it I should apply the base coat, allow a minumim of 30 minutes then apply 2 to3 full wet coats of clear. How long between clear coats? Correct???????????? (and yes I have been reading threads on painting and cannot clearly answer these questions) Thank you in advance Don Danny |
I just used the same on mine. The clear mixes at 4:1 I believe. It was a month and a half ago. Have the tech sheets in garage still.
And Hicswa is correct, that stuff will give a hellof a buzz.:willy: |
Don't start painting until you have proper safety equipment. You may not get a second chance.
http://forums.corvetteforum.com/pain...ocyanates.html |
