dashboard clicking- electrical
Having electrical issue with 2009 corvette. When I get into car and close the door I get a series of clicking sounds from the middle of the dashboard. If I then press on the brake prior to starting the car I get another series of clicks. When shutting the car off I also get a series of clicks. This is definitely not the brake relay. However, if the car is off and I step on the brake I get a series of clicks that repeats if I let off the brake and wait a few seconds and then depress the brake again. The car runs fine and there are no other electrical issues. Any thoughts?
Normal. I get the same thing as did my Dad on his 07 vert.
It is all those 430 horses lining up to go. :D
It is normal, I assume, as my 2012 GS has exactly the same noises prior to startup every time. |
same here.
Mine too.
:woohoo:I get it too. I think it's the horsepower faries under the hood making sure everything is right
Normal, in a sense it's an electric car.
Normal.
The clicking sound is the sensor looking to detect a key fob.....I believe. |
Same here on my 07. The car has over 28 onboard computers. Get used to it. :thumbs:
