409hp @ 6k rpm and 427lb ft of torque @ 3500rpm?
I was thinking of tryin to build an engine using these specs,
this is out of Ryans engine combination and bible site. (Combos 93 to 100) http://www.ryanscarpage.50megs.com/combos13.html Displacement: 350 cu. in. Carburetor: Holley 750 double-pumper Heads: GM L31 Vortecs, pocket-ported, with 1.94/1.50 in. valves Intake: Edelbrock Performer RPM Vortec Camshaft: Comp Cams Xtreme Energy 268 hydraulic, with 0.478/0.480 in. of lift and 224/230° of duration @ 0.050 in. of lift. Exhaust: Hedman 1 5/8 in. headers Distributor: HEI Comp. Ratio: 9.4:1 MAX HP: 409 @ 6000 MAX Torque: 427 @ 3500 The vette I have is a 78 with a 3.08 rear and freshly rebuilt TH350 with original stall torque converter. My question is, how would an engine act that reaches its peak torque way before max HP is reached. I chose it cause it looks cheap to build "non roller cam". What would be a good stall speed and rear end gear. Thanks |
24-2600 stall
3.50-3.70 gear 700r would be really fun with the lower first gear, would pull OD just fine on the hwy Wouldnt sweat where torque/hp peaks are on this one With an AFR 180 head that combo would really tear it up on the street!! |
Originally Posted by SPC Meyer
(Post 1581787155)
