Thoughts on Scion FR-S as Daily Driver?
Thinking of getting into a 2013 FRS for daily driving. Biggest objective being something that's fun to drive and entertaining while commuting. Planning to test drive in the next couple of weeks, so we'll see how that goes.
I've also been kicking around a used 335i, GTI and possibly 2011 and up Mustang GT. Currently leaning toward FRS based on everything I've read about the car. So, what do you guys think? |
335i without question
If you like the FRS, I would definitely suggest the Subaru sister instead. If I'm not mistaken, I think it has a slight power bump. I think it looks better as well, and can be had with more options.
Originally Posted by redvette77
(Post 1581832974)
Still looking at other options, but for $25k I think it'll end up being this or a used 335i. Only downside to 335i is that it's 800 lbs heavier and may not hold up that well on the road course (overheating issues), if I decide to track it. |
Haven't driven either but from what I've read, the BRZ understeers a bit more while the rear end on the FR-S is a little more playful. Here are some long-distance/longterm tests:
http://blogs.insideline.com/roadtest...13-scion-fr-s/ http://blogs.insideline.com/roadtest...13-subaru-brz/ http://www.topgear.com/uk/photos/100...t86-2012-09-10 Also: http://forums.corvetteforum.com/othe...-brz-pics.html http://www.pistonheads.com/doc.asp?c=52&i=26168 For track work, maybe a 128i with wheels/tires, coilovers and brakes might work better than the 335i. Quite a few cars on the market now at $19k and even less. |
For strictly $25k, 11-12 Mustang v6 track pack(used base ones are as low as $20k). Already a car that performs far beyond its price tag, and being a mustang, it has a proverbial butt ton of aftermarket support, as well as factory upgrades(take off parts from gt500, Boss, and GT guys upgrading) like the 14" brembos that are a direct swap. And check out its engine bay, it just may be the single easiest engine to work on since it was designed to fit the broad shouldered 5.4 s/c.
Dont forget the lighter 135i's too, unless you dont like their quirky proportions. And remember, neither those nor the 335i's I believe have a limited slip diff. Stupid, but true. The twin turbo 6 in the earlier years is fairly over-engineered. The thing can keep boosting more and more and take a beating. I cant in good faith recommend the BRZ/FR-S. The "numbers(results) arn't what it was designed for" line is just code for poor engineering. Yeah 200 hp is "enough" for its buyers, but a 2.0 reving to 7400, with 12.5-1 compression, just screams they decided to get by with the bare minimum. |
Have a friend that has the Scion and loves it. Says it's one of the best cars he has ever owned. He has had benz's, vettes, supra, ...etc. Says it is fun to drive and does everything well.
Originally Posted by Guibo
(Post 1581833259)
http://blogs.insideline.com/roadtest...13-scion-fr-s/ http://blogs.insideline.com/roadtest...13-subaru-brz/ http://www.topgear.com/uk/photos/100...t86-2012-09-10 Also: http://forums.corvetteforum.com/othe...-brz-pics.html http://www.pistonheads.com/doc.asp?c=52&i=26168 For track work, maybe a 128i with wheels/tires, coilovers and brakes might work better than the 335i. Quite a few cars on the market now at $19k and even less. Not crazy about 128i. I already track my C6Z06, so would likely not mod for the track. It seems that FRS would perform well on the track without any additional mods. What caught my attention with the Scion is that people keep saying how much fun it is to drive, which is my main objective for DD. :cheers: |
Originally Posted by IMXCITD
(Post 1581834064)
Originally Posted by McGirk94LT1
(Post 1581833519)
Dont forget the lighter 135i's too, unless you dont like their quirky proportions. And remember, neither those nor the 335i's I believe have a limited slip diff. Stupid, but true. The twin turbo 6 in the earlier years is fairly over-engineered. The thing can keep boosting more and more and take a beating. I cant in good faith recommend the BRZ/FR-S. The "numbers(results) arn't what it was designed for" line is just code for poor engineering. Yeah 200 hp is "enough" for its buyers, but a 2.0 reving to 7400, with 12.5-1 compression, just screams they decided to get by with the bare minimum. I keep going back and forth on the power. My Z puts out 500 at the wheels, so I feel that no matter which daily I get, it will not feel powerful/impressive. Anyone feel the same? |
Originally Posted by bright1984
(Post 1581834321)
Thanks for all the links!
(Post 1581833519)
Read this before you decide:
http://www.motortrend.com/roadtests/...n/viewall.html Guibo is correct in that the car enthusiests who grew up with 100 HP Honda Civics and Acura Integras don't necessarily need or want cars that get 16 MPG and are 3600+ lbs. An older generation still buys these cars but the younger generation is just not into it or are savy enough to end up with a light, turbo import that handles extremely well. |
(Post 1581834434)
Forget the 335is, they have had major reliabity issues. |
Not sure if you've already seen my thread, but I recently purchased a BRZ as a daily driver. I have an LS7 powered C5 as my fun car and think the BRZ makes a great daily commuter car.
http://forums.corvetteforum.com/othe...?highlight=Brz |
Go for it, especially if you have some windy backroads nearby. I got to test drive the Scion version and even with the Prius tires it comes with, it holds very well in corners and the oversteer is very controllable. A very fun car to go 10/10 with.
(Post 1581834321)
:cheers: |
Originally Posted by BillY2KFRC
(Post 1581836993)
http://forums.corvetteforum.com/othe...?highlight=Brz I would also be driving it through the winter, so hopefully some winter tires and sand bags in the trunk will do the trick. :cheers: |
Thanks to everyone for thoughts and feedback. Much appreciated.
:cheers: |
I wouldn't totally bypass the Hyundai Genesis Coupe given that price range.
Originally Posted by Dave68
(Post 1581836693)
A friend's wife has a 335i and it completely died on her, one day. Apparently the fuel systems for those engines have a high failure rate. That friend has a 330 4-door that had one headlight go out on him. After having it in the shop for two weeks, they found the problem and charged him $800 to fix it. Sadly, some people keep going back for more "punishment".
