Hardened output shafts
I did a topic search on these and didnt yield anything except this provider: http://www.markwilliams.com/pdfcat/pg15.pdf
$590 seems a bit much. Any other recommendations out there? |
Re: Hardened output shafts (rwj383)
<A HREF="http://www.txspeedworks.com/output_shaft.cfm" TARGET="_blank">SpeedWORKS - http://www.txspeedworks.com/output_shaft.cfm</A>
:cheers: JC [Modified by The One, 11:20 AM 6/4/2002] |
We sell our diffs with the hardened output shaft for $350 extra. $1545 exch.
Re: Hardened output shafts (The One)
The Mark Williams prices are for the half shfts.
Call SpeedWorks - they have some I believe - and or are in the process of getting some made..
Best, :cheers: |
I got mine from The Vette Doctors. Give them a call. I believe it was around $300?
Check out this thread: http://forums.corvetteforum.com/zerothread?id=296917
Glen5839 have made a very strong unit in hardened 4340 steel which is much stronger than any other unit I've seen. I have one of the first made and it's a very high quality craftmanship. :cheers: |
Re: Hardened output shafts (seanr)
...Glen5839 have made a very strong unit in hardened 4340 steel which is much stronger than any other unit I've seen. I have one of the first made and it's a very high quality craftmanship. From Metal Suppliers Online - Material Property Data Sheet "300M is a low alloy, vacuum melted, steel of very high strength. Essentially it is a modified AISI 4340 steel with silicon, vanadium and slightly greater carbon and molybdenum content than 4340. 300M has a very good combination of strength (280 to 305 ksi), toughness, fatigue strength and good ductility. It is a through hardening alloy." JC |
I did a topic search on these and didnt yield anything except this provider: http://www.markwilliams.com/pdfcat/pg15.pdf $590 seems a bit much. Any other recommendations out there? |
Re: Hardened output shafts (chuckster)
Mark williams is selling half shafts. The output shaft that most people break is what connects to the left side half shaft.
Two different products. Eric |
Re: Hardened output shafts (66ImpalaLT1)
Mark williams is selling half shafts. The output shaft that most people break is what connects to the left side half shaft. Two different products. |
Re: Hardened output shafts (MattG)
Doesn't the output shaft go between the transmission and the differential?? |
Doesn't the output shaft go between the transmission and the differential?? JC [Modified by The One, 5:23 PM 6/4/2002] |
Just checked the manual(Volume 1, Section 4), half shafts are referred to as axle shafts.
One of the tuners at the last Route 66 Corvette show broke a half shaft/axle on the strip. The Mark Williams half shafts would be a good investment for serious drag racers and as far as I know Mark Williams is a quality manufacturer. Matt, check with Nick at ARE, I'm sure he knows the name Mark Williams, it might be a product he would want to carry. |
Re: Hardened output shafts (Arnie's C5)
Bottom line, what is the labor to R&R this output shaft? It might be more wise to just buy a new diff built with this 300m steel shaft?
There is, indeed, a transmission output shaft. However, the shop manual also identifies the shaft in the differential as an output shaft (if memory serves.) I had an image of the manual page and will post if I can dig it up. http://www.corvetteforum.net/c5/froz...loded_view.jpg Item 22, left output shaft. |
Re: Hardened output shafts (ToplessTexan)
JC |
Sure, everybody knows what #22 is! :D I didn't take a pic with the legend in it. I should have imaged it with a scanner it rather than a camera but Linux doesn't talk to my scanner. :( I owe you an email ;)
