•• Will be Checking a New Set of Factory LS7 Heads ••
Have a new set of stock, replacement LS7 heads and will disassemble and record the guide dims tomorrow.
Probably they are good but can't tell until bore gauged. |
:lurk:
:lurk: me too..
Garry |
Originally Posted by ranger1
(Post 1582192219)
:lurk: me too..
Garry |
:lurk:
Looking forward to this.
Are you also going to check the angle if the guide center to seat?? And I would assume you are going to do the concentricity of the guide to the seat?? Just curious how much analysis you will be doing on the geometry.
Thanks a ton for doing this, hopefully it will shed some light on this whole issue. |
curious too
Very Cool... Can't wait to hear.....
:lurk::lurk: Mark:flag::flag: |
Originally Posted by 240sx2jz
(Post 1582192511)
Thanks a ton for doing this, hopefully it will shed some light on this whole issue. This should be fun! :lol: |
Charlie, you da man! :thumbs:
Is there a known date of manufacture??:bigears
could you check with a dial indicator the amount of stem movement at the top of the stem when assembled with spring...this way people can compare their movement to fresh head movement to get idea how much wear they may have...without pulling their heads..:thumbs:
Originally Posted by RFZ
(Post 1582194185)
And, :bigears |
Originally Posted by Undy
(Post 1582193683)
These are two years old - never been run or bolted on. |
(Post 1582194185)
(Post 1582192511)
So generally from stock the valves are perfectly meeting, but only goes to crap after the guide wears. So guide wear comes first is what I take from that. :)
Originally Posted by mistermog
(Post 1582194775)
subscribed, thanks for doing this. With GM saying there are only 6.5 out of 1000 out of spec in that time frame, who wants take bets the guides are out of spec?
