spark plug gapping qusetion?
i need to know the gap needed for ngk tr 55 spark plugs. thanks in advance.
Re: spark plug gapping qusetion? (jofre_69)
The factory manual spec is .060". I gapped mine at .057"
Edit: Tightening torque is 11 lb.ft. [Modified by Patches, 3:43 PM 6/8/2002] |
Re: spark plug gapping qusetion? (Patches)
The factory manual spec is .060". I gapped mine at .057" Edit: Tightening torque is 11 lb.ft. [Modified by Patches, 3:43 PM 6/8/2002] I did the same thing at .058 ... |
Please clue me in. Why would you use a smaller than recommeded gap?
Thanks. |
Re: spark plug gapping qusetion? (THamilton)
I have installed two sets of these plugs in two different cars. All of the plugs out of the box were at 0.057. I upped them to the specificed 0.060. In the end, I don't think the 0.003 will make any difference. You may want to just check them as they come out of the box to make sure you don't have a out of tolerance gap and then just install as delivered.
I gapped at .055 with no problems.
