wtb front pinion shims for dana 44 3.45 pinion
bought a kit with all bearing and shims but the front shims aren't the proper size for the 3.45 pinion. Anyone know of shims availability.
Thanks Ron |
Dana 44 Shims
Try Tom's Differentials. They are in Idaho.
www.tomsdifferentials.com I have dealt with them in the past, they are very reliable and very helpful. |
Originally Posted by coneracer
(Post 1582467572)
Thanks Ron |
Thanks for the info that might be what I got. Oddly enough the lock nut is the correct size but the front shims are to small.
Thanks Ron |
Do you have an aftermarket gear? I bought a Yukon kit and the pinion crush sleeves were to small in Dia. for the factory 3:33. Yukon said the crush sleeves are for aftermarket gears(smaller pinion shaft dia.) They say to use the shims on the factory gear to set pinion preload. Just a thought. Good Luck!
(Post 1582473750)
Thanks Ron If there's a drive-line shop in the area check them, transmission shops frequently also do differential repairs so if you know what thickness you need you could try there also. |
