Power brake vacuum hose
Hi , does anybody knows the difference between GM 342411 and GM 354698?
The 342411 and 354698 are both 11/32 pipes with a fitting on one end used from carb to power brake booster
Hope this helps.......:thumbs: |
Hi thanks yes I know, but is the same item?
GM lists both as being same...............possibly different manufactuers
Originally Posted by my 76 ray
(Post 1583033714)
The fitting that screws into the carb is much longer on one.
