Over 90 Parts For Sale!!! Cleaning House!
PRICE REDUCTIONS!
UPDATE 2-21-13: The picture link below has been updated to just show what is left for easy viewing Ok, decided to clean house this weekend. :willy::willy::willy: These are all parts from my barn find 69. Over 95% of the parts listed are direct from this 350/350HP machine... I went my own way with the build and did not use most the original parts. I have listed these by a number 1 - 105. I have also made a link to all the photos below. Since there are so many I just published it this was as putting them all here would have been a mess. Also a few items such as the center caps and rings, jack, etc I had not taken picts of. If interested PM with email and I will send picts then. SEE PHOTOS HERE: http://sdrv.ms/XHfuV6 I listed the original price if you were to buy this today (ya had some time on my hands this weekend). And then I listed my asking price. If you are serious about a part and need additional picts PM me and provide and email address and I will send what you need. Also, I did not list blots, etc. But I do have several original bolts from the car as well. Most would need a good washing and wire brush. But have the head codes, etc. I will only charge what it would cost me to ship depending on the part. And will fullfill requests ASAP. I do have a day job so please give me a little room to pack and ship (not Zip Corvette after all). If you have any questions, please PM me as this thread may get large. Once a item is purchased I will make it sold on the post. Also, PayPal only. Sorry guys but don't wish to deal with checks or cash. Payments can be made to bdchase73@gmail.com. Oh, one last thing... I MAY trade parts for the following (and only these possible parts) Looking for high quality as well. 69 Door Panels, Corner Windshield Trim Pieces, T-Bar Headliner Panel, Inside Door Pull Handles Hope you find something you can use below! I feel I have tried to price these parts fair (at least 50% off), but if you think i am off the mark make a reasonable offer. PLEASE NOTE THE ITEM NUMBER WHEN ASKING OR PAYING FOR PARTS ON ALL CORRESPONDENCE. Thanks! Item - Description - Price New - Price Used 1 OEM Interior Wiring Harness & Engine Harness $689.00 $250.00 REDUCED! - $200 2 OEM Door Harness (Power Windows) $159.00 $100.00 REDUCED! - $75 3 OEM 350/350 Distributor (Fully Rebuilt W/New Parts Original Distro REBUILT NEVER USED) $399.00 $350.00 REDUCED! - $300 4 NEW NEVER USED Chrome 45,000 Colt Coil $40.00 $35.00 5 NEW NEVER USED Pretronix Module (Sold with Distributor Only) $0.00 $0.00 6 OEM Radio (Mono, unsure if it works) $50.00 - OBO - SOLD 7 OEM Mono Amp $35.00 - SOLD 8 OEM QuadJet (FULLY rebuilt and refurbished) $360.00 $250.00 REDUCED! - $200 9 OEM Standard Transmission Lock Cable $15.00 - SOLD 10 OEM Steering Wheel (Very Good Condition) $269.00 $125.00 11 OEM Center Console Plate (blasted & repainted) $239.00 $50.00 12 OEM Front Rotor Dust Guards L/R LIKE NEW (priced each) $40.00 $20.00 13 OEM Center Gauge Bezel (blasted & repainted) $139.00 $75.00 - SOLD 14 OEM Console Parking Brake Cover (pwr window, sml crack) $120.00 $50.00 15 OEM L/R Door Handles (priced ea) $55.00 $20.00 16 OEM Door Lock Trim Plates (priced ea) $34.00 $8.00 17 OEM Blower Motor (tested and working, blasted & repainted) $30.00 $15.00 REDUCED! - $10 18 OEM Wiper Limit Switch(tested and working) $27.00 $10.00 - SOLD 19 OEM High Beam Floor Switch $9.00 $3.00 20 OEM Hood Cable Boot (from firewall) $7.30 $3.00 21 OEM Parking Brake Bracket (blasted and painted) price ea $10.00 $5.00 22 OEM Alternator Bracket Lower W/Bolt & Nut $71.00 $35.00 REDUCED! - $25 23 OEM Alternator Support Arm Upper $18.00 $10.00 REDUCED! - $5 24 OEM Dash Ball Retainer $15.00 25 OEM Driver Side Dash Air Vents Qty 2 priced ea $50.00 REDUCED! - $35 26 OEM Passenger Side Dash Air Vent (damaged flap, missing) $5.00 27 OEM Seat Belt Buckles L/R Priced ea $98.00 $50.00 - SOLD 28 OEM Driver Side Kick Panel W/Curtsey Light (minor damage) $50.00 $15.00 REDUCED! - $5 29 OEM Rear Headliner Panels (some damage or cracks) $150.00 $25.00 REDUCED! - $15 30 OEM Clutch Pedal Return Spring (blasted & repainted) $7.00 $3.00 31 OEM Wiper Actuator Boot $15.00 $5.00 - SOLD 32 OEM Misc Vent & Heater Controls $20.00 33 OEM Door Shims Qty 4 (Priced ea) $5.00 $2.50 34 OEM Blower Relay (not tested) $11.00 $5.00 35 OEM Interior Warn Buzzer (tested) $15.00 - SOLD 36 Brake Pad Pins New Qty 4 (Priced ea) $1.50 $0.50 37 OEM Rebuilt Speedo W/New Face Plate $299.00 $225.00 REDUCED! - $200 38 OEM Rebuilt Tach W/New Face Plate $134.00 $75.00 39 OEM Speedo Face Plate W/Speed Warn - Used $31.00 $15.00 - SOLD 40 OEM Tie Rods L/R + Clamps & Bolts (not org bolts) Priced ea. $24.00 $15.00 41 OEM Master Cylinder (blasted & repainted) W/Cover Power Brakes $120.00 $75.00 42 OEM R/L Plastic Head Light Covers Sold as a Pair $37.00 $15.00 43 OEM Thermostat Housing & Gasket $55.00 $35.00 - SOLD 44 OEM Gas Tank Filler Neck (think I have new scrws as well) $80.00 $40.00 45 OEM Batt Ground to Frame Cable W/Gasket $55.00 $25.00 46 OEM T-Top Belts (harware needs rechromed) $15.00 47 OEM Diver Side Mirror $55.00 $25.00 - SOLD 48 OEM Heater Coil $70.00 $35.00 REDUCED! - $25 49 OEM Fan Cowl W/Support Bracket $199.00 $125.00 - 50 OEM Lower Cowl $80.00 $40.00 - SOLD 51 Spinners (not sure of year) Sold ea $41.00 $20.00 52 OEM Front Exhaust Mount (blasted & repainted) $32.00 $15.00 53 OEM Windshield Corner Trim (needs plated) $100.00 $15.00 54 OEM Hood Release Cable (mounts to hood) $39.00 $15.00 55 Chrome Air Filter Cover and Element (Eldbrock) New $29.00 $15.00 56 OEM 350 Air Cleaner Base W/Spark Arestor $75.00 $40.00 57 Timing Chain, Fuel, Water Pump, Crank Seal Kit New $10.00 58 KnN Filter New Never Used $55.00 $25.00 - SOLD 59 OEM 350 Valve Covers 1 Refinished Priced ea $150.00 $75.00 60 OEM Speedo Cable New $25.00 $15.00 - SOLD 61 350 Sml Block Water Pump Rebuild Kit $5.00 62 OEM Front Turn Signal Gaskets Pair $4.00 $2.00 63 OEM Coil Bracket (Blasted & Repainted) $22.00 $10.00 64 OEM Gas Filter Bracket $10.75 $5.00 65 OEM Clutch Fork (Blasted & Repainted) $100.00 $50.00 REDUCED! - $30 66 OEM Fan $209.00 $100.00 - SOLD 67 OEM Fan Clutch (date code 8-11-69) $147.00 $75.00 - SOLD 68 OEM Oil Gauge (not tested) $64.00 $30.00 -SOLD 69 OEM Water Gauge (not tested) $29.00 $15.00 -SOLD 70 OEM Batt Gauge (not tested) $60.00 $30.00 -SOLD 71 OEM Fuel Gauge (not tested) $65.00 $30.00 -SOLD 72 OEM Gauge Cluster Light $15.00 -SOLD 73 OEM Gauge Black Plate W/Light Shields (blasted & repainted) $15.00 -SOLD 74 OEM Cast Iron Original 350/350 (Intake Hot Dipped) Date Code E279 $200.00 $75.00 75 OEM Harmonic Bal Pulley Original $60.00 $30.00 - SOLD 76 OEM Distro Hold Down Clamp $10.00 $4.00 77 OEM Water Pump Pulley $99.00 $45.00 78 OEM Pistons 350/350 11:1 $100.00 $50.00 79 After Market Crank Pulley (OEM See Above If Desired) $52.00 $25.00 80 OEM R/L Headlight Bezels (Rt Crack, can be welded) Price ea $60.00 $25.00 - SOLD 81 OEM Passenger Side Healight Cover (Crack, can be welded) $299.00 $100.00 82 OEM Ash Tray Cover (Blasted & Painted) $25.00 $5.00 83 OEM T-Tops Primed (ready for paint) Price ea $100.00 84 SS Fuel Line (new in box) $42.00 $20.00 - SOLD 85 OEM Fuel Line (pump to carb) $40.00 $10.00 - SOLD 86 OEM Valve Cover Vent Elbow $13.00 $5.00 87 OEM Front Nose Support Rod $21.00 $8.00 - SOLD 88 OEM Wiper Solenoid Door Actuator (mounted behind tach) $80.00 $40.00 REDUCED! - $25 89 OEM Ash Tray Housing (blasted & painted) $38.00 $10.00 REDUCED! - $5 90 OEM 350 Exhaust Heat Riser (needed blasted) $47.00 $10.00 REDUCED! - $5 91 OEM Rally Center Caps (GM Qty 4) Price ea $74.00 $45.00 92 OEM Rally Trim Rings (GM Qty 4) Price ea $90.00 $50.00 REDUCED! - $25 93 69 Car Jack (blasted and painted) "A" mark on jack $175.00 $75.00 - SOLD 94 1/2" Crager Offsets $40.00 $20.00 95 OEM Non T/T Horn Button W/Emblem $49.00 $20.00 96 OEM Wiper Control Switch $35.00 $10.00 97 OEM Blower Control Switch WO AC $29.00 $10.00 98 OEM Rag Joint Lower $15.00 99 After Market Temp Sensor New $2.50 100 OEM Vent Knobs Pair $12.00 $5.00 101 OEM Shifter Plate $18.00 $4.00 102 OEM Trip Reset Cable $62.00 $30.00 - SOLD 103 Seat Belt Retainers Pair $20.00 - SOLD 104 OEM L/R Vent Cables Price ea $22.50 $5.00 105 OEM Fiber Center Console Panel (Blasted & Painted) $30.00 $5.00 PLEASE NOTE THE ITEM NUMBER WHEN ASKING OR PAYING FOR PARTS ON ALL CORRESPONDENCE. Thanks! SEE PHOTOS HERE: http://sdrv.ms/XHfuV6 |
PM sent
if the master cylinder is for non power, i would be interested, is it 5455509? if it is i will take it
Originally Posted by Kaper220
(Post 1583146493)
Pm sent
C3 parts.
You have a PM.
pm sent on #58, 60, 84 and 102
I'll take #75 Harmonic Bal Pulley Orginal $60.00 $30.00
PM sent concerning jack date code
General Info: I have had many requests for the jack. I have the jack at the body shop as it was just blasted and repainted. I will get the jack for additional pictures and will post the date code at that time. After that, first come first served.
Brian |
Pm sent for # 's 27, 47, 87, 103 will take all
Think I am caught up with everyone as of now. If I missed anyone, please let me know so I can get you want you want. ~Brian
Pm sent
pm sent on #10
Ok, think I am all caught up! If you purchased parts and did not get a shipping notification please let me know asap. But think we are good to go. Also, anyone that asked for pictures should have them by now as well. Thanks again all... Hope I am helping you all out some, and you are helping me by getting my 4 year 69 on the road this year.
ttt
corvette parts
i am interested in #39 the speedometer face with speed warning. I have sent a PM.
amazingly well presented. GL!
If those harnesses were for an 80 I'd snatch them up.... |
Originally Posted by finallygotit
(Post 1583179563)
If those harnesses were for an 80 I'd snatch them up.... Everyone on the forum I have met and talked with has been a massive help to me on some technical issues. Just a a way for me to finish my project and give something back. Side note, still have quite a few parts... If anything catches your eye let me know. I am not against a fair offer as well. Brian |
ttt
